ME again! lol.
tried the search but does not come up with anything useful.
I noticed my clutch fan is wobbly. Does it mean it needs replacing or is it a matter of tightening it some how?
If i needs replacing i read there's different types i can get e.g viscious or something?
What would be best for my r32 gts-t?
What parts will i need?
Rough prices?
Where to get them!?
And most important is there a DIY to change it? Can't seem to find any on the forum!
Thankss!
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/
ME again! lol.
Rough prices?
Where to get them!?
Thankss!
If its stock you'll have a viscous fan that works by oil expanding in the oil galleries of the clutch which will turn the fan on and off.
Piss the shitty viscous, belt driven, power robbing SOB off and go electric on a thermostat bro.
James
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5630614
They dont really rob much power at all, and are work better then some thermo fan setups.....
Check all the bolts, it sounds like something is wrong... Is just the plastic part with the fins loose? or the whole thing (viscus hub as well)?
Might have loose bolts on the water pump but id think if that was the case youd have lost it by now.
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5630676
The viscous hubs is effective to 4000 rpm before it slips. There isnt a 12V fan in existance that can move the same amount of air that the factory fan can, and if there were they dont make an alternator big enough to drive it. The engineers that designed the factory cooling system know what they are doing. If its in good shape it works very well.
Messing with thermostats messes with your tune too, so keep the stock temp thermostats unless your planning on making massive changes to how your tune works with temperature compensations.
Just fix the factory setup and it will be great.
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5630757
Below is the link to daviescraig part numbers for new clutch if you want to keep the original set up, I am guessing you just unbolt your old fan and remove the clutch and bolt the new one in.
http://www.daviescra...uide%202010.pdf
I think you may need a 5265 http://www.daviescra...65-details.aspx and it looks like they are about $194.04 from that site.
If you want to got electric fans like i did $366.00 for 2 x 12" fans plus $68.77 for the manual thermal switch so thats = $434.77 plus postage i guess, then you would also need to get it all wired up for them to work.
As I can do wiring this part didn't cost me anything.....
Edited by pfcr33
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5630892
agreed^^^
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5631015
Unless you fully understand the principle for the usse of a thermo fan, and know how to properly install it and properly operate it, stick with the factory setup. I'm sure Nissan knew what they were doing when they decided on the use of the viscous clutch type against a thermo setup.
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5631577
also adding more load to the alternator also robs the engine of power, so getting rid of a clutch fan in favour of thermos doesn't give you that much of a power gain. i used to be able to stall my festiva with my sound system turned right up.
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5631675
What you need is
1. New fan clutch (Get a davies craig one as mentioned above)
2. New radiator fan shroud
3. Timing belt cover with CAS sensor rubber seal
4. 3 bolts for the CAS sensor... not 1.
All of these things are critical. 3 especially, as RB's are interference motors. All it will take is a bolt or socket dropped into the timing belt area and you will slip or break the timing belt and destroy your engine.
What you have there is the downside of a modified vehicle. So many modified vehicles are mess with, without any comprehension of what happens when things go wrong... or with little to no regard for how Nissan designed them.
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5632607
What you need is
1. is a fan shroud necessary? i've got an aftermarket radiator? don't think it will bolt on to it?
2. is the clear covers ive seen okay? eg.(unless someone can refer me to get a cheaper/better on else where) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=370435414621&ssPageName=STRK:MEWAX:IT
3. there only 2 bolts holding the cas. for the 3rd would nissan dealer stock them or i'd have to go wreckers or something? (btw... it seem even the metal thing holding the cas also wobbles??)
thanks
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5632710
I generally prefer original parts as they fit better, rather than some cheap aftermarket thing. You can probably pickup a stock cover cheap 2nd hand from someone else that bought a clear one.
You need this gasket too.
http://cgi.ebay.com/ebaymotors/Nissan-OE-RB25DET-Cam-Angle-Sensor-CAS-Seal-Gasket-RB25-_W0QQcmdZViewItemQQhashZitem2eb20ef2f9QQitemZ200555819769QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
The gasket and the cover together are a spacer that goes between the cas mount and the cas. When its mounted properly it shouldnt move. You obviously need a timing light to align it correctly as well.
The fan shroud is meant to pull air through your entire radiator, not just a small section in front of the fan. Larger cores have more coolant volume and when the air flow is sufficent they can lower coolant temps faster than a thin stock core. But because they are thicker cores the air flows through them less easily. So you actually need a shroud more for an aftermarket core for low speed driving than you would for a stock core. Above 80km/h the fan is mostly not in use.
There is a lot more to it than that though. The thermostat of the engine, the engines ideal operating temp, the heatsync on the front of the thermally activated clutch fan, the rpm of the fan and the load of the fan itself all work together in concert to work properly. Nissan design these things very carefully and the complexity of it goes a lot further than most realise. This is why stock is best for reliability and consistancy, and also why most aftermarket/custom setups only work in specific situations. Modify something and you upset the balance Nissan created.
Edited by GTRNUR
https://www.sau.com.au/forums/topic/350850-clutch-fan-help/#findComment-5632739
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
