hi guys, these are 18x9.5 +18 all round, rears have plenty of room still but fronts sit flush.
I think car should be obvious as to what it is. Lol
I'm gonna run 19x9.5 when I can afford to. Not sure of offset tho, I think rear should be slightly lower offset to the front.
I would do very bad things to own a set of 18x9.5" Regamasters.
I'm surprised how many people like these wheels, I'd never heard of them until my mate bought these. They do suit my car pretty well. Maybe I should offer him some coin...
i'm trying to sell my rims so i can get a set of these:
http://cgi.ebay.com.au/BB5-LM-BBS-STYLE-19-INCH-BMW-VW-AUDI-ALFA-NISSAN-TOYOTA-/270698021749?pt=AU_Car_Parts_Accessories&hash=item3f06dc0375
cheap knockoff's - yes, but i'll never be able to justify the cost of genuine LM's and nevvvvver in 19 inch.
these come in 19x9.5 +20, which should sit nice.
otherwise i'll just keep my axis hiro's 19x8.5 +28 and space them out, because they look rather weak.
question though, can i use a 20mm on the front and a 25mm on the back? or do they have to be the same all round to avoid upsetting the ATTESSA?
Never heard of them before, just googled them, not much of a fan really
can someone please tell me if these sizes 18x8.5 +32 18x9.5 +12 will fit my S1 auto? as i am hopeless when it comes to knowing what size will fit
Cheers
Assuming the 8.5's are front, and 9.5's are rear, I think they will fit (although front might hit on your shocks? Not sure on that) but it wont be worth it. Rears would need a bit of guardwork, lowness, and camber so that it didnt look mexican, and the front would be fairly sunken, wouldnt match the rears at all.
You would also need to run different size tyres front and rear to maintain the same rolling diameter between front and rear, so that the ATTESSA system doesnt chuck a tantrum.
Thanks,
Would you be able to tell me what would be the right offset and widths for s1, wanna get some bronze CR Kais
Thanks,
18x9 all round is a good size imo (although 9.5's can easily fit), but it really all depends on what look you are going for. I am running 18x9+18 all round on mine, with 235/40 tyres. The rears sit pretty nice, but the fronts need to come out a little bit, I am going to use 15 or 20mm spacers at the front, whenever i get around to it. The C34 front guards can take pretty low offset wheels compared to the rear, especially when everything is stock.
Remember, you can use different offset at the front and at the rear without a problem, it's only having different width wheels that messes the ATTESSA up. So you could go 18x9+15 rear, and 18x9 0 front if you wanted to. Just depends how aggressive you want to go.
This is how mine looks (still needs more low dry.gif)
IMG_0088.jpg?t=1296639713
IMG_0070.jpg?t=1296639811
IMG_0076.jpg?t=1296639810
If you don't run a spastic rim width stagger you could just do same size tyres all round too, I'm sure the difference in how a tyre seats on say a 9 and 10" rim wouldn't make enough difference in diameter to faze it.
  • 1 month later...
Sorry to ressurect an old thread but which would you guys recommend for an S1 auto RS four;
17x9 +15 or 17x9 +20?
I don't want to modding guards. I just want to bolt the wheels on and enjoy.
thanks for your help!
I have 17x9 +30 but I think either of the above would be fine - depends on your suspension. The front track is narrower than the rear so I have 20mm spacesr on the front - 25mm would be ideal but 20mm is now the legal max for spacers here.
I bought some 18x9 +20 (215/45 tyres) and 18x10 +21 (235/45 tyres) wheels while I was in VIC picking the car up.
the rears should work out perfect w/o the use of camber arms, but they are a little close to the rear shock, it looks like it should clear by 5mm or so, but I'm hoping BC don't use a thicker shock case otherwise I might run into some issues.
Fronts aren't as aggressive as the rears, so I'll probably use a 10mm bolt on spacer to make it look even and have similar fitment all round.
Edited by RoadsterGarage
The stagea you bought is a AWd RS4 right??
You will have big issues if you run those tyres. Need to be the same rolling diameter front to rear.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
