why? theres twice as many joints to fail..
Yeah only if the joints used are under rated for the application. Many 500hp applications still use the factory tailshaft.
2 piece shafts are stronger. It's a fact and any driveshaft specialist will say the same.
Going back to a previous post by someone, the falcon tailshaft made from alloy....Aluminium is lighter, therefore it has a much higher critical speed and they use a 3inch tube from memory. The longer the shaft, the stronger the material has to be or you have to lighten the shaft and/or make the tube diameter larger as well. The larger the diameter and the lighter it is, the critical speed goes up further. That is why carbon fibre shafts are probably the best material you can use. Extremely strong, extremely light.
About 6 months ago I got my 2 peice rebuilt from my 300rwkw R34. 1st drive I popped the clutch at about 4k RPM in 1st and blew 3 uni joints to peice's. I then returned said tail shaft and it was then forwared onto spicer, who refused to warrant the parts as they beleived I had either put huge power or locked the shaft some how. My question was, "how would you suggest a way that I could snap all 3 uni's in 1 go with out smashing out the bottom of my car?" they couldn't answer me. Luckily the workshop that built it for me where as confused as I was and met me half way with building a complete new 1 peice shaft.
A 1 peice shaft deffinitly transmit alot more vibration into the car but from what I can tell should almost be indestructable as it's much bulkier then original.
regards
Chris
About 6 months ago I got my 2 peice rebuilt from my 300rwkw R34. 1st drive I popped the clutch at about 4k RPM in 1st and blew 3 uni joints to peice's. I then returned said tail shaft and it was then forwared onto spicer, who refused to warrant the parts as they beleived I had either put huge power or locked the shaft some how. My question was, "how would you suggest a way that I could snap all 3 uni's in 1 go .......................
regards
Chris
Got any photos?
Reason I ask, the shop I use does routine maintenance work for BMW and Merc. Both these cars have non-replaceable uni joints same as the Skylines.
Whenever I get a shaft built it's done with new yokes that have conventional circlipped-in replaceable unis, there's very few Nissan components left when he's finished.
BUT the guys from BM and Merc won't have non-original components on their cars, they have the peened-in design yokes machined for circlips, pass them over to him and he re-builds the shaft.
There's practically no metal left in the yokes.
I'd be interested to see if your re-built shaft was done that way.
Got any photos?
hey Jiffo,
unfortunatly I never took any photo's of the shaft when it sheered all the uni's. I know exactly what your saying, yes the shaft was the peened style and machined the yoke to suit the circlip style. when it failed, none of the actual yokes broke, it sheered the actualle centres out of all of them. I would have though that machining the yokes would have caused them to be weaker and snap there first but it didn't.
Chris
lets see. i wonder what most race cars and drag cars use.. as long as the driveline angle is in check (most of the time its not..) i cant see any problems. besides a longer shaft will have more twist and hence be nicer to the unies..
i had massive issues with mine... and i needed a new cv joint.. but apparently... (i got told) that there is i think it was 3 bearings.. like a centre and a front and a back...
it was weird...
But i dont know too much about tailshafts.... plus i think that mechanic was dodgy....
lets see. as long as the driveline angle is in check (most of the time its not..)
Exactly right.
99% of owners don't realise you must run your flanges parallel.
That usually means packing the diff, stiffer engine mounts and some serious dimension checking.
Comparing a 25 box with a sliding yoke to a GT4 box with an output flange is also useless, the shaft must have some in/out flexibility either from the CV or a spline.
Running a sliding yoke style box with a worn out extension bearing is also asking for vibrations.
A stock 2-piece will let you get away with a lot of these faults, they may not even be noticed by the average driver, but a 1-piece will show them up big time.
Wonder how many 1-piece owners have fitted a shaft hoop where the centre bearing used to live?
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
what sort of horespower are the stock 2 piece shafts cappable of?
i know someone earlier said they have been using around the 500 to 600 hp mark but what application are you using your car for? street, drift, drag, track?
if anyone is using a stock shaft with slicks at the drags would be handy to know the following..
*horsepower
*revs on launch
*tyres being used
cheers
  • 1 month later...
  • 3 months later...
just ordered myself a one piece cromolly tailshaft of uniqiue autosports for my r34gtr it has 360klw at the wheels,will let u guys know how it go's fingers crossed i dont get problems, its totally made will all new parts and its costing me $1500 john seems to know his shit we running a cv type flange on the rear and beefed up unis on the front with mark williams yokes
  • 7 months later...
I have a new shaft being built atm, im running 3 inch heavier tube, with uni's that are a 30mm cap x 90mm uni with external clips and all replaceable uni's. Will be a 2 piece shaft. The builder said they make them for 1000hp drag cars with no failures. Should well exceed my needs.
where are you looking at getting these built from? is their specific shops that specialize in performance tailshafts?
Hardy spicer
Fark! i've got a 1 piece built by ADL, it's been fine so far, fark! i'm going to have to change it
Why?
Hardy spicer
Why?
Ring any tailshaft maker in your area and they should tell you that a tube shaft of the length required in a skyline (I think it's around 50inches) will go critical at 6000-6500rpm. The harmonic inbalance is usually so harsh that they bend or buckle as a result.
Of course it depends on the material they are made from, how thick and the diameter of the tube but 2 piece shafts are stronger, much stronger. We put 600+hp through them all the time without hassles
this info seems to be on the money, my shaft is just over 50 inches :whistling: , compared with 4wd which is around 10 inches shorter
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
