Seems to be a pretty good thing, but when he says "everything" has been replaced 2000k ago... That's tens of thousands of dollars, excluding motor and gearbox, as the bloke on here who really has restored one will attest
Yes, true. He says he has all receipts though, so I'll wait to hear from him.
if its what he says then go for it. good price......but it does say always kept under cover, and its outside in the rain for the Photos...
i doubt it has been restored to the extent that the one here on the forums has been (that is just nuts and i cant find the link off the top of my head).
But either way, for 22 grand with that list and those Km's and it runs well with reciepts (if he has em) you cant really go wrong :)
Haha, yeah I thought it was a bit ironic that its sitting out in the rain, I'm assuming he just put it out there to take photos, and it's in QLD so hard to avoid rain lately
basically that's what people say when they car is kept in a garage at night. it doesn't mean that it has never been out in the rain, etc. if you were to take "it's always kept under cover" literally then it must mean that whenever it is driven he has some sort of cover over the top of it, or only drives it in an under ground carpark.....
so it's always kept under cover, except for when it isn't.
f**k that is cheap for being "restored", i'm actually restoring my 32 4 door atm and passed that asking price ages ago just getting door seals. Would be good to see some more pics
The colour of the seats is not to everyone's taste. However, no-one ever goes to that much trouble unless he/she's an enthusiast
However, he/she doesn't say that the restoration was actually done by him/her. The English simply says "...my restored..."
It's worth looking at - and your enquiry might pay off; but I'd check on how long he/she's had it and when you look at the work receipts, ask for permission to check all details.
Seems strange that it would have one when its got N1 turbos aswell. Pretty overkill for that kinda power level
vcam is worth like 25% of what he is asking for the whole car
pull the other one terry ;)
we all know that tacky leather seats are just as common on fully sick bro cars that get THRASHED as they are on enthusiast cars
if you go look at it take a screwdriver with you and check the inside of the sillsbehind the carpet. if it has had the full resto then those should not have any rust in them.
seats do not belong to that car. the label on the side is an airbag label so the are out of somethe later.
I would ask for every receipt available. I can tell you now that if it was done right he will produce a BIG pile of receipts totally at least $20k.
also take a fridge magnet so you can look for bog.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
