I quickly checked the Tomei price. Cooling channel version $3000 for the six, normal version $1780 delivered. the Mahle pistons are approx just over half as much.
As far as coating go I wasn't bothered with titanium this or that, or ceramic coating the crowns - more interested in a low friction coating for the piston sides.
HKS - part number 2103-RN017
lists as $2124 delivered.
2103-RN021 lists as $1585 delivered.
So the Japanese stuff doesn't appear to be particularly good value. It may, however, be more suited (As opposed to more generic although that is just conjecture)
How do Mahle pistons go for noise?
I'll have a look for Ross stuff also.
yeah you're right. for anyone without an unlimited budget these days the jap pistons are kind of priced out of reality. I can say though they are very good and seem to last. and very quiet too. dunno if that makes them worth twice or tripple the price of competing chinese and american pistons but they are good.
you can have the coatings done to any piston after you buy it but HKS (and others do offer various coatings) including a low friction molybdenum skirt coating like you want.
not sure of the mahle noise haven't paid attention to the one local engine I know with them in it. CPs seem to be not bad noise wise.
  • 3 months later...
Can I ask where you ordered them from?
i got em though a forum member brand new when he ordered a set for him self. we went halfs in the postage and it came in welll under 1k. like 800dollor mark for 6 with everything pins, rings, the lot
: D
yeah I currently have tomei pistons in my car and as I said (and piggaz said) they are so quiet. you would not know the car had forgies and they are strong as they come. not cheap, but a pretty critical component so I don't mind spending a bit on pistons.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
