i jacked the car up nice and high to day and i have noticed i have an oil leak
it appears to be the return oil line for the front turbo.
general area around is oily but not dripping!
i am pleased to have found this as i have a new set of gt2860-5 along with Tomei manifolds and dumps to go in the next 2 weeks
i hope this is the only oil consumption
That may be part of it, but I wouldn't go getting excited and fitting new turbos and manifolds until you have the root cause correctly diagnosed.
Don't half do it, have the leak down test done by a competent workshop.
i dont think a leaking oil return would result in your breather collecting that much oil. i know you've got a case of wishful thinking but if you make the hard decisions early you can save yourself more damage being done to the motor.
dont learn the hard way.
Just so you know, nissan spec for oil consumption is 1L every 2000kms. Anything higher then that is deemed unacceptable. However you blowing smoke, so i would be gettin a leak down test asap.
1L in 2000 km's, you serious? Maybe in a 300,000+ km engine it would be acceptable
No, it's even worse that that!
Nissan say acceptable is 1l per 1,000klm. We fought with them for year about our 350z which did exactly that, they never fixed it.
The old LS1s all consumed almost 1L/1000kms which is why half them had to be warrantied, there is still quite a few going around that couldn't get warranty using almost that much oil though.
A new car used 1L/1000KM???
Did they eventually sort it out after 1 year?
Stories like that make me never want to buy a brand new car. We did about 3 years ago and its been really good, but it was always in the back of my mind if something major went wrong car manufactures can make life very difficult.
P.S. Sorry to go off topic.
Regarding the bloke who started the thread, are you getting the leakdown test done. Surely a workshop could do this at short notice for you or even the engine builder could do it for you??
thats a warranty cop out (all manufacturers have the same clause), i worked for nissan and depending on the attitude of the customer and its previous use we made report, then a decision was made to replace or build engine. We actually replaced a few blown nizpro engines under warranty for the special edition 200sx-R's they built 10--odd years back.
i took the car back to south side engine center today
they did comp test (4psi of variance across all 6 cylinders)
leak-down test (6-7% leak down across all 6 cylinders)
put a camera down the spark plug holes to inspect the bores and condition of the pistons.
and all looked sweet i had a look myself!!.
conclusion i have been told to put my new turbos on
put new O2 senors in
change oil and get tuned car tuned asap as it is running too rich witch may be washing oil from the bores
so as it stands i'm very happy with the result.
Is this info in the owners manual???
the leak down is pretty bad?
My 100,000 old RB25DET engine that ran 200rwkw for about 2 years had 2% leak down across all 6.
I guess different testers would give different values but i would think what is more important like compression test, is the variance between individual cyls ?
Hmm. We have had a petrol navara in at work which had a problem with using excessive oil. Liased with nissan's techline and told us to do a ECU relearn with a patch file they sent us. Apparently one of the banks reads a little leaner then the other, and this can cause excessive oil consumption. Did the relearn and its seemed to fix the problem.
The info is not in the owners manual. Basically had to ask one of the nissan engineerers for the specs.
did they explain why a lean mixture will cause oil consumption?
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
