I bought a brand new gt3071r from some guy who was meant to put it on his car but ended up using something else. Anyway, by my own fault, I assumed it was a t3 gt3071r as I was under the impression all gt30 turbos(well majority) are t3. This one though is a t2.
Could I run a t2 to t3 adapter? Its a .86 rear and the front is .50 or some shit.
Cheers.
https://www.sau.com.au/forums/topic/352190-gt3071r-is-this-bad/
I think room will be fine. I just need this clarified.
Is the ONLY difference between a T2 .86 and a T3 .86 the flange? Is the housing the same size? Will the flange size be restrictive or will it open up inside the housing to allow the same flow of exhaust as a T3 just be abit tighter up front? I don't want to hit 5krpm then watch a downhill decent...
they have a different turbine. In general; cropped gt30 in the t2 housings vs uncropped gt30 in the t3 housings.
Though the .86 t2 sized housing is roughly equivalent to a .63 t3. OK for a 3071 on an rb25 though the internal waste gate size may be marginal.
I was considering trying this exact turbo. Could be a cheap way to get near GTRS performance on an RB25. I would expect it would be slightly restricted by the smaller flange but it depends on your power goals. GTRS (2871) don't make all that much power anyway. A full turbine 3071 will give more top end but at the expense of response. Some would say you might as well go 3076.
No they do both 84 and 90 trim turbine versions . Turbo number 700382-3 using cartridge number 700177-3 has the 84 trim turbine where unit 700382-20 with cartridge 700177-4 uses the 90 trim turbine variant .
Also all the so called HKS GT2835 variants use the T2/25/28 flange size except the Pro S ones which are T3 footprint .
I think the easiest turbine housing solution would be for Garrett to machine their GT30 IW ones to match these cropped turbines , a cropped GT30 turbine would work better in a GT30 turbine housing than GT28 ones IMO .
A .
Yeah I didn't be more specific before. The 90 trim TURBO part number is .86 but has a housing option for .64 and the TURBO part number for the 84 trim is .64 but has a .86 housing option. I assumed the turbo is just an off the shelf Garrett part. My bad.
Ah shit forgot about HKS T2 flanges
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
