Jesus nick I can't believe your building another motor!
Nice, can't wait to see it out and about... Powercruise this year?
The rb26 came with the car so this is the first motor I've built for it(and hoping to keep it that way). Powercruise would be nice but I'm not sure it'l be done by then... starting the understand the meaning of time poor :(
nice mate! you are a brave man to buy fatz's old 31... lol. :) full credit to keeping it going and tidying the old beast up. I've been in it years ago when fatz first put the XR6 tubz on it with fatz laughing like a giant school girl beside me as he drifted the thing. not the safest feeling in the world!!
it's always been a cool car though and with the new full race set-up and the weds it looks shit hot.
Brings back memories of the test drive before I bought it lol.
  • 3 months later...
Bit of an update. Still going backwards (stripping parts from the car) but getting closer to the point where I can start putting it back together.
Sound deadening is next up, then it's off to the fabricator.
Std body wiring loom is weighty, looks like custom is the go.
Picked up a flat wheel - great bit of gear
JE/Nitto pistons, Nitto rods
External oil pump, sump with external pick-up / trap doors etc and drive mandrel for the ati balancer.
Dummied up (not my engine)
Some time before heading to the drags it was reversed into by a careless council worker so I took the opportunity to fit a uras kit and a wingless boot. Std 4 stud rear axles were fitted so it could be driven to the paint shop and a few weeks later into storage.
It looked pretty odd with std 4 stud wheels!
Revised catch can (routing blowby to the back of the car)
OS quad plate, pita to fit with the motor in - would have been a lot easier to remove the motor & box together and work on it that way!
Just my luck, the day I flew out the bloody axles arrived....
Roughly 1 month after leaving we returned to Perth for a friends wedding... the plan was to fit the axles, shoot the car for HPI, check the tune and get to the drags again.
Sean at ASG ran it up on his hub dyno, without the slipping clutch and wheelspin the 6boob related boost control issues were even worse, with boost creeping to 1.7bar.
Unfortunately bad weather saw the drags cancelled, but at least the axles were fitted.
Axles fitted
And the rear wheels back on.
The weather meant we weren't able to get any good shots for the article besides a few in the garage..
It was then back into storage for the end of '08 and most of '09.
What Wheels Are they Mate and where did you pick em up from?
  • 5 weeks later...
Not really much in the way of interesting updates. I've stripped all the sound deadening, hopefully picked up a fresh head with some larger cams, springs, retainers (more on this when it arrives) and the new turbo finally arrived. Geoff at fullrace talked me into going larger than I had originally planned, together with inconel studs etc.
Motivation...
Re-tapped the manifold M10 x 1.5 for the inconel studs, quite the pita with very shallow tapped holes. Getting just on three turns on the shallowest of them which is border-line ok.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
