Hey Guys,
Just thought I'd make a new thread for my GTS Build instead of flooding the other one.
Here is the before shot
One ugly, poorly maintained, unloved skyline. Set me back $3500.
It's a 1996 R33 Skyline GTS, that's been turboed; albeit poorly.
Previous mods included:
Stupid head unit that's totally unfathomable.
Apexi PowerFC with Commander.
Greddy electronic boost controller.
lots of B&M gauges mounted on the dash.
FMIC
Stock R33 turbo that didn't have the water lines connected to it.
17" Multi fit 5 spoke mags.
Inside the car it was all pretty good, a couple of cigarette burns but that was about it. Exterior was less than perfect, on the drivers side there was a deep scratch all the way along the door and the drivers side guard had some damage too, looked like someone backed into it. Paint needs a good cut and polish but should come up OK.
The car's engine was quite broken and had some noisy bearings so that had to come out first thing. Gearbox had also seen better days and a replacement is on the way.
Suspension\bushes\steering..... lets just not go there OK, it's quite broken.
As far as clapped out Skylines go I think I took the cake.
The original plan was to drift it the way I got it and see how I went from there, seeing as everything was broken and such activities would have been dangerous\insane I decided to bite the bullet and spend the big bucks up front to get something nice.
So now, the exciting bits...
the shopping list goes like this
Engine
Nissan N1 Oil & water Pumps
Nitto Crank collar to suit N1 oil pump
New Low temp Thermostat
Nitto 1.2mm head gasket
ACL Race bearings
Nitto Forged Pistons
Nitto forged H-beam rods
Machine Head & Block
Linish crank
Bore and Hone
Nismo 740cc injectors
Tomei Poncams
Management
Haltech Plug in Pro ECU
Turbo
Garret 3076R
Powertune high mount manifold
44m Tial Wastegate
Suspension
BC Adjustable Coilovers
Tune agent Adjustable Castor Rods
Whiteline blade adjustable Swaybars
Drivetrain
Stock RB25DET gearbox
Tomei Traxx 1.5way mechanical LSD
Roll cage
Built by AZ.
Brakes
Atm they're stock NA brakes.
Not sure what to get as yet
I've also changed the hubs to 5 stud ones.
We're aiming for about 300 plus KW
Nick and Ben over at GT garage are doing all the work for me and they're doing a wonderful job too! Couldn't be happier.
Here are some pics of the cage going in.
Plenty more to come :D
Edited by zoidbergmerc
  • Like 1
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/
nice man.. as for brakes, try find some R34gtr brembos? or AP 6 pot fronts :P
gtr brembo's are so overpriced
you can get 34 gtt brakes for about $400 (310mm)
or the ksport ones from justjap are big for cheap (~350mm rotor and 8pot brakes, $2k)
but someone has started a group buy on willowood 6pot 332mm kit for $1.8k which would be pretty good (it uses 2 piece rotors so they are lighter)
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5656552
I saw this the other day when in GT, cage looks the goods.
As for brakes I'd go std R34 GTT with fresh 'rebuilt' callipers (new seals etc) with braided lines, plain (or slotted, but never drilled) fresh rotor with Ferodo DS3000 pads and some decent fluid like Motul RBF 600.
Pretty much exactly what I'll do on my R34 (cept maybe with a more streetable pad)
Oh, and a line locker may come in handy :P
Good build, can’t wait till it’s done!
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5656569
GT-T brakes are good, but aren't even close to GT-R Brembos. You get roughly what you pay for.
KSports are charlie chan china rubbish.
Can buy 330mm 240SX wilwood superlite kits out of the states for ~$1500 to your door.
Instead of GT-T brakes you could always just grab some stock GTS-T ones, dogbones and 330mm rotors.
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5657281
yeah I want to keep my 17s for cheaper skids so I reckon the R34 GTT Brakes are going to have to do, I'll just some nice fluid and pads.
Does anyone have R34 GTT Brakes they want to get rid of?
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5658726
  • 3 weeks later...
Almost finished now. Dummy fitted the engine, turbo and plenum so Az could work his magic on the front, dump, screamer. and IC piping. Did a fantastic job too :D
High Mount Manifold made by Az Custom, should look the goods once it's painted! Can see the screamer in there too.
Big ol Sexy front pipe.
Plazmaman Plenum and Throttle body ready to go.
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5702348
Hey mate, looking good. Very interested in seeing the outcome :) Have you driven it much with the whiteline sway bars on? I'm looking at grabbing some of these myself but have been struggling to find any decent reviews for R33's. Also, what're you thinking of for front/rear strut brace?
Jay
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5702988
I've driven this car from the Docks in Hobart to Moonah and that was it; the engine integrity was too low to continue. Strut braces were already on the car when I go it so I guess I'll keep them, not sure what brand they are.
I've got whiteline non-adjustable sways on my WRX and they totally transformed the car, the difference is day and night, knocked the understeer on the head and enabled me to get some nice turn in oversteer if I require it.
Once this car is going I'll be sure to tell you all about it :)
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5703049
putting a bodykit on mate? painting it? wot wheels u thinking? looks like ur investing some decent dollars into it, how far away from completion is it? looking good! can't wait to hear the screamer ;)
I got a TypeM plastic front end for it the other day from another member on here. Looks nice with the rest of the standard kit. I might see if I can get some new front guards to replace the ones on it as the drivers side has some damage on it.
As for paint, white is OK for now, I'm trying to convince a mate of mine who is a very talented artist to airbrush it but he's rather nervous about it because he's not done a car before.
Wheels I've got a set of 17" Gmax Drifts in white for it, might make them black though. White wheels on a white car... not so sure. I've also got the 17" that came on it, they're a little on the cheap\heavy side though.
Yes it's a lot of money but it's also going to be a lot of fun :D Plus Nick at GT Garage is looking after me thumbsup.gif
Thought it would be best to do it now while I've got some money before other stuff like houses and children come up.
https://www.sau.com.au/forums/topic/352798-zoids-gts-build/#findComment-5704140
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
