Brand New Stainless Steel DRIFT PIPES
Up for sale is my stainless steel drift pipes, they are universal and have no flanges on it, i was going to put this on my 33 but decided not to so therefore i am selling them, im unsure of what brand they are well fabricated and i cant pick a fault within the welding, im looking for around $220 ono, 3 inch outlet with 3 inch pipes!!!
Contact me on 0402930153
Bunch o' goodies for sale - get in quick for bargains!
Bride Zeta III + Rail / Erg 4 Point Harness / Yokohama Advan Semi Slicks A050 18 Inch / Ecliptech Shift Light / Ruzic Controller / Sparco Removable Steering Boss / R32 Gtr Front Seats
http://www.skylinesaustralia.com/forums/topic/403156-bride-zeta-iii-rail-erg-4-point-harness-a050-18-inch-shift-light-ruzic-controller-sparco-removable-steering-boss-r32-gtr-front-seats/page__view__findpost__p__6411551
I have an adjustable 24mm whiteline front swaybar up for sale, used for roughly 6 months, no longer needed as car has gone back to standard.
It is to suit R32 Gts-t, Pics can be arranged.
Asking $220 $200, payed around $280 for it new, whiteline list them on there site for $299 currently. Grab a bargain!!!
0407 633 573.
For Sale:
180sx tail lights $80ono
180sx bonnet latch $30ono
180sx bonnet hindges $30ono
180sx SR20det compressor housing outlet pipe $30
180sx Glass Headlights with H4 globes $50ono
180sx centre air vents $20ono
180sx A/C controls $40ono
180sx SR20det fuel pump $40ono
180sx SR20det oil cap $10ono
I'm not sure what these parts are worth exactly so i'm putting these prices with "Or Nearest Offer"
Pics can be seen at this link
http://www.facebook.com/media/set/?set=a.10150190043393592.323992.642283591&type=1#!/media/set/?set=a.10150190043393592.323992.642283591&type=1
Contact me via PM or txt me on 0433 522 234
Located South of Adelaide.
For Sale
Set of work XT7s 18 x 9.5 +30
BEautiful condition, like new! Only on car for less then 5 months. dont look like 2nd hand wheels!!
Tyres are easily 90% and are 245 40 18s
will suit Mitsubishi and nissan + others 5x114.3
Pics dont do these justice!! Happy for test fits etc
$1850 without centre caps or $1970 with centre caps
tems:
12" 2011 Cadence Sub+Amp and wiring kit.
Item Condition:
Used for about a month in my old daily. Been sitting in my room for the last year. Need it gone.
Contact Details:
PM
Price and price conditions:
Looking for cash sale open to offers. Need it gone. Located down south.
Got my R33 S2 front bar up for sale, Has the bottom lip and comes with indicator/fog lights. Has 1 crack on the bottom lip and there is some visible silicone the body repairer used to hold the lip on but its not too noticeable (see pics). Paint is good, the car is filthy in the pics.
$350ono
0425151620
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
