Tial 38mm external wastegate $250
GT3076 housings, front and 5 bolt .63 rear $200 the pair
33 rear strut brace $100
33 gtst front rotors and caliper $300
17" black meshs, new near front tyres worn rears $600 (plus give me your stockys)
33 Cusco adj Coilovers $700 (plus give me your stockys so my shell can roll)
R33 s2 running gear $1800 minus engine loom and ecu
still wrecking silver 33 hit me up
AM Performance R33 exhaust
2.5" twins in to 4" out with titanium tips.
$700 ono
Sparco Sprint seat, brand new, blue with white stitching
Comes with brand new rail, fit drivers side r32/r33/r34/a31/c33, will also fit s13/14/15 but one hole will not line up
$550 firm
R33 2dr GTST s2 door trims with switches etc
$50
HKS super power flow filter, mushroom style, brand new 3.5"
$50
Simota pod filter, brand new 4"
$20
PM or call/text 0422 314 938
Also, Mitsubishi Evolution 7 for sale with fruit, needs to go asap due to work commitments:
http://www.carsales.com.au/private/details/mitsubishi-lancer-2001-13651683
FREE: rear cards for 2dr R32 gtst, need a good clean. Also have great condition aircon unit + fan unit + heater core and a few ac vents. Come take em or they're goin in the bin. Other bits for sale: Q45 AFM $100 - R32 gtst climate control $40 - interior light $10. Make an offer!
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=409913
Last chance on these. Bin on Monday.
Also have a Free R32 gtst back seat, needs a clean up. Good to get you through regency. Come get it or its goin in the bin!
Edited by Sammy B
r33 aftermarket fibreglass front bar
no structural damage just needs a bit of fibreglass repair for a few chips on it
$50
r33 ignition barrel, and two door locks + key to suite all - $70
JBL 1000 watt sub in box $75
and still got r33 s1 front guards in red 100 ono
and a cat converter in perfect cond. 75 ono
just want all this stuff out of the shed asap
PM only cheers
Got a 2002 Cozmo Haro BMX Bike FS with pegs
Been sitting in the shed for years and want it gone. $300 negotiable
Has some minor surface rust/pitting on the chromed bits but everything else is in good cond
PM me for pics
-D
Toyo Proxes R888's for sale only (33GTR rims already sold) 17x45x255 - will need to confirm when i get the tires back from having them removed from rims.
Only done a few track days and a hillclimb so in good condition.
Prefer Adelaide buyer, located south of Adelaide, may be able to drop off or meet for sale.
Prefer text/call as i rarely get on here these days.
$650
Ash: 0488446696
Edited by mr_rbman
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
