Set of Genuine Volk GT-C's in silver, 17x8 +35 Face 1 and 18x9 +38 Face 2. Fronts clear big brakes, they clear my brembos easily. Fronts in excellent condition, rears have a few small marks on the chrome lip.
Front tyres are stuffed, Rears have 245/40 Potenzas with a 1mm or so left.
$900 Need these gone ASAP!!!!
Well under the price i want for them but i need them gone!
Contact me on here or on 0407 633 573 for pics.
Hi everyone,
I have a brand new and unused set of Karbonetic carbon fibre wheel arch flare set to suit R33 Skyline for sale.
Price: $320 (negotiable)
Price drop to $220!!
http://www.skylinesaustralia.com/forums/topic/412985-fs-sa-karbonetic-carbon-fibre-400r-wheel-arch-flare-set-new/page__gopid__6650823#entry6650823
R33 gtst sr1 manual complete rear cradle diff to brake with slotted rotors and hicas lock bar $300
R33 gtst sr1 front 5stud hub, knuckle, lower and top arm, abs wires and brake hose $100 each side
R33 gtst sr1 power steering rack and cross member $100
R33 gtst sr1 manual rb25det complete wire loom with z32 plug and turbo timer $100
R33 gtst sr1 heater cores that sit behind the dash all three units $50
Pm me
Dave
got a few bits for sale.
all south adelaide pick up.
best to contact via txt as im at work alot at odd hours.
RB20/25 S/S turbo manifold, top mount with 50mm ext wastegate port. used $150
RB25 standard turbo manifold $50
RB25 standard inlet manifold with injectors and throttle body $80
RB20/25 braided oil feed for turbo $50
R33 bootlid, S1 wine red, small bit of surface rust on edge $50
R33 short shifter (ebay cheapie, needs screws $40
Got some goodies for sale, sold the car and no longer need these
Greddy e-manage ultimate
Blitz i-color SBC
Greddy turbo timer
I just want the stuff gone so not keen on negotiating price
just make me an offer.
Adrian 0421289321 prefer SMS
0425366582
Blitz i-color SBC
Greddy turbo timer
As per the rules, you need to list a price first mate
SRI front strut brace suit ecr33/er34 (blue), hasnt been used only test fitted. - $60
HEL braided brake line kit, both front and rear lines, suit ecr33 and possibly r32 gtst, only been test fitted and havent had fluid through them. - $125
Six NGK Iridium spark plugs (NGK BCPR6EIX-11) Brand New $50
For sale full r33 exhaust system minus catalytic converter unknown 3inch dumpipe to a 3.5inch pipe with one hot dog muffler going out to 2.5inch twin pipes from exhaust technology 400.00 dollars
Can send pics to phone msg me on 0422 102 617
Hey got a few bits for sale
Rb20det low mount stainless turbo manifold,new never fitted
$150
Rb26 intake plenum to suit rb20
Cut and shut to suit the rb20
You run the 6 GTR throttle bodies
Still use the rb20 injectors
Comes with almost everthing to fit except gaskets
$600
R32 GTR nismo strut brace
Matt black colour with brake master stopper
$200
R32 front camber arms
Fully adjustable
$150
Rb26 rocker covers (stock black)
Coilpack cover (blue needs paint)
Nitto clear cam cover
Rb26 cam gear backing plate
Everthing you need to bolt them to your rb20
$500
Blitz I-d SBC all parts you need to install in your car
$400
Alpine type s
15inch subs x2
$500 pair or $250 ea
Part no... sws-15d2
Rb20 hks cams
 264-9mm lift cams
Hks adjustable cam gears
$750
S14 subframe
Bare no arms
$100
S13/r32
Soils subframe bushes
$100
R33 turbo
Front calipers
$150
R33 bn side skirts and
R33 bn rear bar
Suit 2 door coupe
$350
0431 391 262 Luke
Edited by skyline_r33_panda
Motorola Razr V (xt885)
1 week old, selling as my Dads plan was upgraded and he doesn't like touch screens.
Comes with charger, headphones, case & screen protec
tor. Comes pre loaded with current top paid games. Android 4.04.
Optus tell me its unlocked. IMEI# 352205050296705
$300 ono
Sony Xperia X10 unlocked
Running MIUI (Similar style to iPhone)
Comes pre loaded with some paid games. Includes 2 cases and charger. 4gb mem card. Some light scuffing on screen from daily use. Unable to see any of it with a screen protector on.
Unlocked.
$120
Located Greenacres or Henley Beach.
sms/call 0421 460 040
Edited by awsam
For Sale: Felt Chasm BMX Street Stunt Bike $400 negotiable. What you see is what you get but also have two stunt pegs with the sale.
Reason For Sale: No longer fit on the bike and got other interests.
Condition: Scratch here and there and needs a clean but will be cleaned before inspections.
Txt on 0433 522 234
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
