Contact: O4O29O2759
R33/ S14 Nismo 2 way diff in housing - $700
R32/S13/180sx Nismo 2 way diff in housing - $700
R32 GTR Grill - $130
Apexi SAFC - $200
Bolt on Spacers
30mm - $100 (Pair)
15mm - $100 (pair)
Recaro Seat - $400
XXR526 Wheels - $1000
Brand new, have fitted tyres but they will be removed before sale.
17x9 +25
17x10 +20
SSR Wheels - $600
17x8 +32
17x9 +38
Nismo Wheels (Full set of 4) - $600
P1 Buddyclub (Pair Only) - $250
17x8 +32
Wheels - $1000
17x9 +32
17x10.5 +23
R34 Turbo Coupe Nismo Coilovers - $800
R34 Reverse Lights - $50
R34 Front upper CUSCO Camber Arms - $200
R34 Return Flow Intercooler - $450
R34 Boot Sub Box - $100
Rear Window Spoilers - $200 Each
R32 GTR Mushroom Pod Filters - $200
R32 GTR Apexi Super Intake Pods - $220
R32 GTR Brakes, with Project Mu pads - $550
Front and Rear - Pads, Rotors, Calipers, Drum Rear Handbrake Setup
HKS 3540 - $700
Straight bolt on for RB20/RB25
Lines have been removed since photos and are not included
R32 Type M Plastic Side Skirts - $100 (pair)
R32 Type M Plastic Rear Pods - $70 (pair)
R33 Rear Subframe -$250
Complete with brakes, Driveshafts
Pictures: http://www.skylinesaustralia.com/forums/topic/424403-wheels-turbo-coilovers-spacers-gtr-grill-safc-diff/
Edited by JiN_MaN
wrecking a series 2 silver r33 gtst
text 0421549607 for parts. or pm. no calls, too hard to manage all the parts.
parts not available
bonnet
front bar
reo
brakes
drivers headlight
fairly firm on most prices.
everything is stock minus a 3 inch cat back exhaust with cannon
paint is awesome on all parts.
so
rb25 gearbox with short shifter $1500 can do a full manual conversion for 2k. neg.
rb25 motor $900 with complete intake manifold side including injectors
ps pump 80
alternator 70
starter motor 80
turbo 250
exhaust manifold 50
loom 100
ecu 100
or will do complete motor with the above for 1500
or just add on what you want to the long motor. and add the price.
tailshaft 100
r33 stock wheels with yokohama tyres awesome tread 300
cat back 3 inch exhaust cannon and one mid muffler 150
dump and front pipe 50
2 front guards in red 50 for both
one passenger in silver with some scratches 25
got 2 indicators to go for free with guards.
s2 steering wheel mint 150
boot with s2 spoiler 100.
400r rear bar 150
side skirts unsure of brand but suite the 400r rear bar 75
lhs headlight (passenger) 100
rb25 afm 100
diff 150
dash cluster 134000k's 100
i have mint condition complete interior just havnt sorted out a price yet but will update when i have worked out the price
front seats
dash
back seat
seatbelts
glovebox
centre console
all interior plastics
door trims
window regulators (both work)
other parts havnt sorted a price out for yet are
both doors minus window regs and trim. will include the window motor and glass and mirror.
clutch (unsure what it is yet)
clutch slave and master
engine and gearbox crossmembers
ps reservoir
rear tail lights
tail light surrounds
rear garnish
door locks, ignition barrel and boot lock + key
pm or text and i can get back to you with a price.
can send pics if needed.
All parts to suit R32 GTR/GTS4
Whiteline front and rear blade adjustable swaybars (Front 22mm, Rear 24mm). Includes urethane D bushes and rose joint link kits
All in good condition, bit dirty and what not but hardly had any use over the time ive had them
$500 for the lot, or swap for stock front / rear swaybars with link bushes etc + cash my way
Tein Colovers
No idea what spec, no leaks or knocks, one split boot (as pictured). Upgraded so these have come out
$300
GTR OEM Plastic side skirts + fibreglass pods
As pictured, bit dirty, but overall good nick. Pods fit between the door and the rear wheel arch
Paint code KG1 (Silver)
$200
Taking up room in my garage, all this stuff needs to go. Swaybars are cheap as considering what the whole package is worth new
For sale is a Set of 4 M2 rims they are the original japan drift teck with heaps of Dish. made In Japan
Fronts are 18x9 15 offset
Rear are 18x10 20 offset
5x114.3
brand new tyres Achilles 123s front 235. Rear 265
$1000 with tyres cheap as
no lower so plz don't ask
Thanks.
  • Like 2
parts not available
bonnet
front bar
reo
brakes
drivers headlight
so
ps pump 80
alternator 70
starter motor 80
turbo 250
exhaust manifold 50
loom 100
ecu 100
tailshaft 100
400r rear bar 150
rb25 afm 100
diff 150
front seats
dash
back seat
seatbelts
glovebox
centre console
door trims
ps reservoir
rear tail lights
rear garnish
cat, and cat back exhaust sold, antenna, sun visors, mirror, ash tray, floor mats, passenger door trim, door handle surrounds, head light, all sold.
deposit taken on motor set up minus turbo side pending payment.
more parts for sale
two 5 stud space savers, one 4 stud, $25 each. tyres good and hold air.
rear windscreen in good condition $40
rear window wiper, front window wipers, $15 each
engine mounts $25 each side
s1 front bar indicators $20 each $30 for both
front windscreen $40
ecu plastic cover $10
rear plastic bits next to back seats $15 each side
revised prices
doors are $75 each. great paint no dents or anything. with glass and window motors + rails.
full lock set + key $90
ps reservoir $30 with lines if needed.
gearbox x member $30
seatbelts $10 each
glovebox $10
centre console $25
stereo surround unpainted so good condition no cracks $35
engine crossmember $50
Item: DEWALT 18V NANO LITHIUM ION CORDLESS IMPACT DRIVER KIT-DC827KL
Description: DEWALT's exclusive NANO-phosphate lithium-ion cells deliver more run time and longer battery life and durability for up to 2000 recharges. The impact driver's compact size and weight allows access into tighter areas and reduces user fatigue. Unique frameless motor offers extended tool durability and life.
Features
Frameless motor for extended tool durability and life
Compact size & weight allows access into tighter areas and reduces user fatigue
1,330in-lbs of torque to perform a wide range of fastening applications
0-2,400 rpm/0-2,700 ipm for faster application speed
Replaceable brushes for increased serviceability
Textured ant-slip comfort grip provides maximum comfort and control
Durable magnesium gear case and all metal transmission for extended durability
Heavy duty impacting mechanism directs torque to fastener without kickback
DEWALT exclusive nano-phosphate lithium ion cells offer long battery life & durability: 2,000 recharges
Specifications
Voltage 18 V
Drive Size 1/4" hex shank quick release in
No Load Speed 0-2,400 rpm
Impacts/Min 0-2,700 bpm
Max. Torque 1,330 in-lbs
Max. Torque 155NM
Tool Weight 4.6 lbs
Tool Length 5-3/4 "
Shipping Weight 10.54 lbs
Includes
(1x) 1 hour charger
(1x) 18V Lithium Ion XRP batterie with NANO Technology
Condition: Used but in excellent working order and condition couple marks thats all hardly used
Price: (rrp$419 new) My Asking Price Is $319ono
Contact Info
Call or txt me on 0457599706
Regards: Allan.M
Features
Specifications
Voltage 18 V
Max. Torque 155NM
Tool Weight 4.6 lbs
Tool Length 5-3/4 "
Includes
(1x) 1 hour charger
Contact Info
Regards: Allan.M
Features
Specifications
Voltage 18 V
Max. Torque 155NM
Tool Weight 4.6 lbs
Tool Length 5-3/4 "
Includes
(1x) 1 hour charger
Contact Info
Regards: Allan.M
Features
Specifications
Voltage 18 V
Max. Torque 155NM
Tool Weight 4.6 lbs
Tool Length 5-3/4 "
Includes
(1x) 1 hour charger
Contact Info
Regards: Allan.M
Im so so so sorry about all these double,triple posts i had isp problems thaught it did not post my add so retried few times then this happend could a admin of this section plz tidy it up ie: remove most posts except one please and again sorry for the hassle.
Regards
Allan.M
Car has been sold and want this stuff gone. Pics on gumtree: http://www.gumtree.com.au/m-my-ad.html?adId=1015847989
Mostly series 2 R33 unless stated otherwise:
R33 series 2 front bar with nismo lip (Kr4 silver in colour) $300
R33 series 2 bonnet (Kr4 Silver) $300
R33 series 2 rear bar SOLD
R33 series 2 spoiler (Kr4 Silver) $50
R33 crossover pipe $30
R33 HKS adjustable actuator, bought but never fitted. $50
R33 skyline power fc brand new in box with controller gtst rb25det SOLD
R33 Rocket Cover Kit $30
GFB boost controller silver $40
R33 rear tail light $20
R33 Standard cat back exhaust and rear muffler box $80
R33 Dash silver overlay $20
R33 Gtr 400r indicators $40
R33 Air intake $30
R33 Standard dump pipe $40
R33 Exhaust gaskit kit $25
R33 Rear pods silver $30
R33 Coilpacks series 2 one is dodgey $40
R33 Exhaust manifold Block to turbo $50
R33 Standard Cat $40
R32 Turbo with 25 actuator 1mm of play, think it came off a 32 at 80,000kms and hasnt been on since. $100
R33Standard Side mount intercooler $50
R33 return pipe $25
Everything is in good to great condition.
If i dont answer im at work send me a txt. Brad 0409699742
Hey mate still got the rocker cover gaskets ? are they oem ? and they brand new im guessing
For sale: greddy profec b spec ii black electronic boost controller
Perfect condition in box with solenoid, hoses and all wiring.
$250
can post at buyers expense
Please text Lucas
0413733433
Located Adelaide southern suburbs but travel to eastern Adelaide often for work
Cheers
Profec b sold pending payment
2002 Kawasaki ZX6r, Great condition, well maintained, 41,000kms. New brake pads fitted recently, new Yuasa battery (old cheapy failed), new fork seals done around 6months ago. Lots of tyre left (<12mnths old)
$5,300 neg.
Fresh pictures taken today.
F3956E38-86E3-4483-91B2-F02B91C8D808-132
00855D56-2275-426B-B03C-49D961E0CA4F-132
$5,200
Not gonna quote my post coz its too long but... Rb25 motor, gearbox, shifter, loom, starter motor, alternator, injectors, both doors, guards, stereo surround, front & rear seats, parcel shelf, window switch, roof lining, steering column with indicator stalks, all sold.
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 💪🏼 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
