R33 s2 front door cards, rear side cards and rear seats $200
R33 stock exhaust turbo back $150
300zx 16x7.5 wheels tyres need replacing $200
R33 interior parts $100
R33 stock exhaust $100
300zx wheels $150
Also have a PAIR of volk challange zero 17x9+22 have good tread on inside (camber wear then flipped) $350ono
Got a whole load of R32 parts for sale.
PRICES ARE FIRM.
If it is not listed we don't have it.
RB20DE engine with loom $450
R32 5 speed manual gearbox $350
Front Reo no cuts or damage $150
rear sway bar stock suit s13 r32 180sx $20
boot rubber $20
NA crossover pipe x2 $20 each
clutch fan uncut $20
radiator shroud $40
r32 4 door rubber door seal have both fronts and the passenger rear($40 each)
R32 GTR/r33 rear brakes with discs $120
starter motor $20
air flow metre $50
ECU (can be nistuned) $100
Center console (arm rest part) $70
din console(where the radio etc goes) $70
gearshifter leather $20
center surround (has been cut to suit screen install )$20
under dash panel $20
front coilover pair (dampener and height adjustable) $200
electric Side mirrors each $70
stock arms have 2x camber 1x toe and 1x caster with new bushing $10 each
ECU cover/ flare holder $20
glove box side panel $20
glovebox $30
type S front bar uncut $200
tail lights pair $150
S2 projector headlights pair $200
indicator driver side clear/orange $40
master cyl (new in 2010 have receipt) $50
cluster NA with batterguage blue faced $50
climate control digital $80
TXT or call 0416 580 22 three as i dont check here very often.
photos on request.
If it is listed i still have it and will update as things sell.
prices are firm.
PRICES ARE FIRM.
RB20 R32 gearbox manual $350
boot rubber $20
radiator shroud $40
starter motor $20
air flow metre $50
glovebox $30
TXT or call 0416 580 two two three. as i dont check emails very often.
photos on request.
prices are firm.
F S : V35 Coupe Urethane Nismo Style Front Bumper Bars
If you have ever dabbled with aftermarket bars for the V35 you will come to realise (as I did) that our cars are VERY low, and fibreglass bars break quite easily and are an endless source of frustration.
I finally bit the bullet and ordered one of these awesome copy Nismo urethane bars out of the USA. Then when I got a postage quote of $1,250 I nearly died. So I bought a few to make the postage cost effective, and subsequently have spares for sale.
They are imho superior to the factory Nismo items, as these are made of urethane (in fact they almost feel like rubber), whereas the genuine bars are fibreglass and break with a decent crunch.
The fit is near enough to perfect, and indicators fit near enough to perfect also (unlike the other fg bar I have had, the fit of which was AWFUL).
They are located in Adelaide, but I can ship if required. I would imagine shipping would be around $100-$150 within Aus depending on destination. Weight is around 10kg, but obviously cubic weight is much higher.
$900 each ono (which if you have ever imported one yourself you will realise is a great deal - and saves you the headaches importing them and the issues and costs with customs I won't go into!).
Grab one before I put them on Ebay for $1k each!
These are THE bars for V35s in my opinion, and given they are urethane and almost unbreakable, may be the last bar you ever buy for your V35.
Apexi Power FC Djetro 3BAR MAP Sensor + with cable
Works Perfectly Fine, Removed only because I removed the Power FC a while ago and went back to Standard ECU and no longer needed it.
it is the 3 pin plug NOT the 5 pin, which means the boost solenoid (if upgraded) is run off the same wires that the standard solenoid runs off from the ECU, NOT into the MAP sensors plug then into the Power FC <-- (5 pin plug)
$100 ONO
Hi all :)
FS - APEXi AVC-R Limited Edition boost controller (Black) with an additional new control valve and all instructions - In excellent condition - $375
This is a great boost controller with so many functions :) grab a bargain...!
Hi all :)
Sold pending payment...
SOME BUY BEFORE I PUT ON ON EBAY!
OFFERS PEOPLE OOOOFFFFFEEERRRRSSSSSSSS!!
We got loads of boy racers on here might be interested in..........
Sparco race suit. Triple layered full FIA approved, fire retardant suit.
Black with white stitching. - Im 170cm tall, solid build for idea of size (should be slightly loose for fire retardant to be effective)
black suede sparco hightop race shoes with white logo - US10 (equivalent)
Will supply photos on demand via MMS - 0433 eight three zero 055
Sold my drift car, need to mod the new daily keen on selling asap.
(high top suede version)
Very similar - except black, and triple layered version. (higher spec)
$650 for both.
Paid over $1,000 from autosport in 2012 - Used only 4 times.
Perfect condition.
Regards,
Weez.
For sale in SA
Car: 1998 Nissan Skyline R34 GTT
Drivetrain: RB25det NEO – Semi-auto tiptronic.
Colour: silver
Kms: 120000
Price: $9500 ono !!!!!!!!!!!!!!!!!!!!!!!!11!!1eleventy
Contact: 0413-145-430 or pm me here.
Modifications:
Full nismo/ HKS exhaust
new BC racing coilovers (under warranty)
New slotted brakes/ bendix pads
New titanium window tint
Front mount intercooler
Deleted rear wing (available if you want it)
17” aftermarket wheels with TOYO Proxy tires
Carbon fibre interior trim
DVD double din player
clear front and side nismo indicators
advert here
http://www.skylinesaustralia.com/forums/topic/432754-fssa-r34-gtt-10000/
lol well dont ask me to swap because i have one of thoes too :P
i have concidered selling the RS4-S and keeping the 34....but the wife likes the stag better :P
Edited by GH05T
R33 Items For Sale
R33 Gtst 5 stud Front Hubs- $150 (pair)
R33 Gts 4 Stud Hubs (all four) – $200
R33 Gts 4 stud Rotors (all four) - $60
Front two need to be machined
R33 Non turbo Brakes with allot of meat on pads– (all four) - $130
R33 Lower control arms- $80 (pair)
R33 rear Driveshafts- $80 (pair)
R33 handbrake assembly - no cables = (pair)- $50
R33 Items For Sale
RB25DET neo bottom end for sale
Original bore /pistons with original crosshatch pattern, no lip on top of bores
Perfect replacement for your dead bottom end
Doesnt come with sump or oil pickup, you can use your own if you choose, engine located in Perth so if you have a mate here then he is welcome to inspect
I wilbe in S.A in the first week of october, will be going to unley and holden hill so if you are on the way I can deliver or I can put it on a pallet and send it if you are happy to pay for freight it you are out in woop woop
Chasing $450 or best offer
Engine is on gumtree if you want photos (ad id 1027891245) or can send you pictures if you give me mobile number
If your (GENUINELY) Interested then pm or 0435383471
SOLD !!
RB Ali radiator 60mm $100
R33 cat back exhaust , deletes cat and bolts to your front pipe. X force stainless exhaust one muffler, twin blast pipes in mild steel joined to it. $300 Ono
rb25 purple label afm $70
r33 adjustable front strut brace blue $80
rb25 ps pump $60
R33 manual cluster 120xxx $80
Pm for pics
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
