Also
rb25 engine needs new headgasket 74 thou ks $800
r32 gtr front guards mind condition $400
R32 gtr rear cut for rear guards $800 ono there mint perfect for a repair
R32 gtr dash cluster under 100 thou ks $150
R32 rear cradle complete with ally spacers n lock bar $300
R32 front crossmamber with power steer $150
R32 fuel tank 50
R32 windows Doors Headlights
am performance cat back exhaust for an r32
stainless steel
titanium tips twin staggered tips
mid varex electronic muffler with remote
$600
pictures can be sent if interested. PM me
Selling the exhaust already.
I've got this DVD player that I don't need anymore as I decided to go single din instead so this has just been sitting around in the garage.
It's used but in good condition. Just comes with the unit and the plug for the back with the cables and I'll throw in the cable for the areial adaptor and mounting brackets.
$200 FIRM
I'm looking for a FMIC and an EBC (newer stuff, ie Profec B, AVCR etc no old stuff) for my Stagea so can swap or part swap with some cash your way if needed.
All the details of the unit can be found here:
http://www.clarion.c...2419833216.html
Pictures of the actual DVD player can be found here:
http://www.nissansil...em&item_id=7319
SEND ME A PM AS I DONT COME BACK INTO THIS THREAD OFTEN
Enkei wheels 5x114.3 - Rear: 16x8" Front: 16x7".
Anodized cherry red lip with black center.
Made in Japan, strong and light weight rims.
Great for street or track mags.
This is for a set.
Includes tyres with approximately 85% Rear, 65% Front tread.
Few marks here and there, one little dent on one rim, which really can only be seen when looking for it, doesn't effect anything.
All in all very good condition, awesome looking rims with japanese quality.
$900 ono
FS: Dell Inspiron Mini
10" netbook, black - has very minor wear and tear - works 100%
Includes: laptop, battery, charger and its original boxes and manuals
250GB HDD, 1GB DDR3 Memory, Atom 1.66Ghz CPU, Windows 7 Starter OS etc etc
Specs are here: http://www.dell.com/au/p/inspiron-mini1018/pd
Price: $150
Hey all, Upgrading my S1 R33 GTST so I have a Full turbo kit for sale.
125,000KMS
Standard Manifold, Turbo, Front Pipe, Custom steel intake pipe w/BOV plumback and breather fittings.
All in good order, turbo has minimal shaft play
Doesnt include Hoses or banjo bolts.
$500 ono
Located in Adelaide.
Cheers.
Buddy club P1 wheels x 4
Tyres: 235/45 Kuhmo KU36 80% tread
Condition: Perfect condition.
Price: $1200 FIRM.
No pictures but can MMS if you require.
0433830055
R33 GT-R Wheels x 4
Genuine (NOT COPIES)
Size:17x9JJ +30 all round
Tyres: 235/45 Sailums F: 100% R: 75% tread
Price: $1,000 FIRM
No pictures but can MMS if required
-Weez.
2000 VT II Exective Sedan 4dr Auto 4sp 3.8i $$$ 3,500 ono !!!!!
**** Big Comfy and and good on fuel & did i mention it would make a good tow car ****
Ok so I'll start by saying im selling this for a friend of mine to help them out.
Up for one lucky person is the option to get your hands on a awesome deal on a series 2 VT commadore in matalic dark blue.
This car would be ideal as a cheap daily driver, first car or even tow Car.
The car is completely stock and has has always been well maintained but the couple that have owned it now both have new cars so the VT is no longer needed.
This vehicle has only ever had 2 other owners since brand new.
Features ~
- Clean comftable spacious Interior
- Air conditioning (works well)
- 240,000 owner lives out near oakbank (the 3.8ltr eco tech engines are built tough and most around this age have about 300,000+ usaly)
- CD Player
- Matalic Blue Paint
Feel free to call or text me 0416153371 if Your interested or would like more pictures.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
