ok,
I'm running a pair of Garrett GT 2860 - 7's in my GTR, and i'm getting full boost are 6k, which is way too high in the rev range.
I currently had a Gizzmo MSIbc installed, and I have tried a manual controller and its still lagging.
I fitted the factory boost control solenoid and it ran 8 psi @ 4k which is about right.
Anyone else had a problem with excess lag in a GTR? Or have any idea why its lagging so much?
Mate suggested that the wastegates are opening too early, if this is the case can I restrict them somehow?
Any suggestions welcome
-Michael-
https://www.sau.com.au/forums/topic/355457-car-way-too-laggy/
With proper boost control you should be at 16psi by 4k, not 8.
How did you setup the wastegate actuators?
A friend of mine is having the same problem with his GTR, twin GT-RS turbos, 272 cams, etc... Full boost by 5500rpm. I'll find out whats going on when he gets his car back from the tuner.
GT-RS are far bigger and laggier than -7s. Did you mean GT-SS?
Sounds spot on for those turbos and cams on a 2.6 or 2.8
he said thats whats under the hood, i havnt seen them myself. the car makes 460 awkw though. Would gt-ss make that power??
No way in hell mate, you have GT-RS x 2 there my friend.
GT-SS are hard out pushing 330KW let alone another 130KW on top of that, definitely GT-RS
The actuator rods have a thread on them so you can tighten / loosen them. This would be the first place to look.
Try tightening them up by screwing the end on so the total rod length is shorter. This means the actuator needs to see more boost before it starts opening the wastegate up further.
Well GT-RS turbos - what do you expect? 800hp of turbo isn't going to be responsive on a 2.6ltr
Sounds perfectly normal - and totally unrelated to the OP as he is talking about R34 N1 turbos.
Well you've answered your own question.
The EBC install is incorrect. If you've put the factory setup on there and it was instantly more responsive... Then it's rather obvious where the issue is...
Well if the EBC is the issue, it would have to be simply doing nothing. By that I mean having the same effect as no boost controller at all....would that really amount to that the increase in lag? Sure, it's been proven to be the issue by his simple troubleshooting - yet I can't see how a boost controller will be the difference in 2000rpm
+1. After you tighten the actuators, make sure they are both working in unison by applying boost to the signal line, and making sure they move together. Otherwise you could flog out a turbo.
For clarity, it appears you have two boost control problems.
1. Probably actuatory adjustment
2. Boost controller installed incorrectly/broken.
True this - very important the actuators are configured consistently across both turbos.
OK, i'll take a look at the actuators on the weekend, hope they can be adjusted without removing too much
I'm pretty sure the install is correct, there are 2 lines, one for actuators another from manifold. Boosts to target, just takes too long, old controller did the same thing, that's why I replaced it, thought the unit was faulty.
On the note of take it to a pro, can you recommend someone?
Thanks for the input :)
By target, do you mean higher than your actuator's spring rating? Try running a vac line directly from the boost source off the intercooler piping or wherever you're getting it from to the actuators. Completely remove the boost controller from the equation. You said with the standard boost solenoid in place, it made 8psi? If that's the rating of your actuators, I dare say that's probably the issue. While your turbos aren't HUGE, they're certainly flowing a decent amount of air and therefore exhaust even at that low boost, so I wouldn't be surprised if it was just simply overcoming the wastegate flap and pushing it open.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
