Wow that is a full on turbocharger Bobby I just realised...76mm inducer and 102mm exducer that should be nearing a four figure hp output.
It's a 68.5mm inducer and a 102mm exducer trim 44 this comp wheel is for high pressure ratio I'd like people to copy this theory. Currently modifying a hks turbo for a friend I'll post some results I won't say for now what I'm doing to it once done I'll let people know a nice mod for hks Kai
  • 3 weeks later...
Seriously thick walled wrist pins you've got there! They look to be at least 1-1.5 mm thicker than a standard pin.
I would have thought you would be using titanium rods too for the deck height you are running as well with this engine.
Is that a GT500 2.8lt crank?
Also, whats with the banjo fittings on the back of the head? External oil supply, rather than through a block restrictor?
Bobby, are the photos that you had of the head showing the water/air reliefs still on this thread? If not, can you post them up again please?
Looks great, like the red :) is that a anti-oil friction coating or it just looks cool?
Hi Ian,
John wanted the thickest wrist pin.
The rods are crower and this should be fine, and wont stretch.
Banjo fitting are the external oil supply that we can control how much we want in the head. Trevor the motor builder has said he wants to see more then std in the head.
Yes the crank is a Gt500 2.8L
http://www.skylinesaustralia.com/forums/topic/355547-r34-gtr-build/page__st__360
Yes that red is the Anti oil friction coating
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
