Be interesting to see how you go with the OS Giken box. A friend had a twin T67 R32 GTR with a Trust box that went bang so was replaced with the OS Giken sequential that also went bang. He was making something bonkers like 600rwkws from memory. He gave up on having that much power after the box problems with some of the thinking being that it was part shifting with all 4 wheels blazing in lower gears hurting what I think was 3rd gear. He was running a Fcon so wasnt running ignition cut which I think would make a big difference
Thanks for the advise.
Gearbox breaking is always the case in every high powered Gtr. Ignition cut does help however im trying to go the next step is having sensors in the gearbox for ignition cut to occur when the dog gears are lined up. Motec have done it with Hollinger so ill find out more and get back to you 8)
I have heard that the Hollinger is usually paired with an R32 GTR transfer case when installed in a GTR. The later model transfer cases are somehow different, and doesn't apparently easily (possibly at all) adapt to the R33/R34 transfer cases. (The person that told me this might have not had all the facts too, as seems to be typical for most high end GTR stuff)
I would imagine that becase of this difference, and how the R32 GTR doesn't run a preload on the transfer case it would also make the AWD system slower to respond. Perhaps potentially making the car a little more prone to power over steer compared to the r33/r34's tendancy to understeer. It realyl would be interesting to know if there is a difference. Ive always prefered the R32 to drive to the R33/R34's.
Internal sensor switches that detect when the selector forks are fully in the engaged position is definatly the way to go too. By enabling an ignition cut at the start of the shift and re-enabling ignition when fully engaged you will get the fastest possible reliable shift. Potentially faster than a fixed delay too. Safe shift speeds could vary at low RPM and road speeds vs high RPM and high road speeds, not to mention lubrication viscosity, temperature etc.
If the OS88 is a no hasle direct bolt in, there is no question as to which way to go. One of these is definatly on my wish list.
The Hollinger RB26 transmission will bolt up to any of the GTR transfer cases. There is slight internal clutch differences 32,33&34 but the overall principal is the same.
We've removed hollingers from 32's and swapped them straight into 34's using the 34 transfer case.
Same deal applies with the OS88.
Bobby have you looked into the Motorsport systems strain gauges.
I know touring cars guys who have done what you are contemplating with hollingers and they reverted back to one of Anthony's shifters for shear reliability and simplicity.
The idea of ignition cut isn't to kill ignition for the entire gear change either.
You only need to cut ignition to release the load between the dogs & engagement rings so you can actually pull the box out of gear.
Physically selecting the next gear with power applied to the engine isn't an issue at all.
Knowing when the selector is fully engaged is irrelevant, you only need to know when the gear is about to be disengaged. Strain gauges do the best job as they can anticipate the upcoming gear change by the force being applied to the stick and the Rate it's being applied (fast gear change vs slow gear change requires a different cut time for the time it takes to disengage the gear)
Hollingers old school micro switch "rocker knobs" are just an on/off switch that indicates the stick is being pulled and leaves the cut time to the ecu. It's a constant cut time and doesn't take Into account how hard and quickly the change is being attempted.
Hollinger and Os88 gearbox only fits an R32 or R33 transfercase as the R34 transfer case as a different bolt pattern.
Can you send me Anthony's details and ill call Motec to find out pros and cons about the exact setup
Am using a R32 gtr transfer case however going to run more preload so its similar to a R34 gtr transfer case.
  • 3 weeks later...
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
