Hi Guys,
i know there is a lot of questions regarding offsets and wheel sizes for skylines, but i'm a newbie and haven't found any r33 gtst with the dimensions below
18x8" offset +40 front
18x9" offset +40 rear
my car is lowered 30mm with king springs, will they fit and will i have to do anything to the guards??
  • Like 1
https://www.sau.com.au/forums/topic/356123-wheel-offset-for-r33-gtst/
....It will look fine
But If you wanna be one of these guys that spend a fortune to get the flush look, even though it provides no great performance benefits,then go for it.
EDIT..i do hope your not running standard shocks with those springs..If not you should spend your money on some good quality shocks before worrying about different wheel offsets.
need wider dude....
+40 will look like a bag of dicks
how do you know what a bag of dicks looks like??
Arent you meant o be on some cruise anyway.. :P
It may not look the greatest but it will still look better than most and i think a good quality set of shocks should be of higher priority if they are not done already..Crappy shocks with hard springs and no tyre sidewall = a pretty crappy and unsafe ride
Why put all this pressure on these kids to make their car look a certain way then grumble when they get pulled over and defected because they spend more money trying to look cool rather than actually enhancing their vehicles performance.
EDIT anyway if your that concerned just stick some spacers on them..
What fortune is needed to get the flush look?
i know there is no real standard as everyone like different looks and stuff but thats nice i think.... lol no spacers
and only $850 a few weeks ago on here with tyres..
but as Arthur T3 said just stick spacers in your ones...
Thanks for the feedback guys.. I have replaced the king springs with Tein coilovers just today and the wheel dimensions I put on earlier were for a set of bbs lm replicas.. Does any1 know where I can get a set of lm replicas that will sit more flush?
VarrsToen in the US make BBS LM reps, but they will sit more poke than flush without rolling/flaring/pumping (19x9.5/10.5+0)
18x9+32 all round. Ran fine without modifying the guards. Only time I got scrapage was on bumpy corners...but a guard roll fixed that, and it's completely related to how low/high your car is. But yeah, as Hamish said...you'll be unhappy with the looks after a while, if you don't get offset and width right straight up. Mine look okay, but I'm now trading my rears for 9.5...will make things look even better without the need for guard flaring.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
