hey do i win anything im sure i was first street tyred gtr and first timer at track
No direct prizes for that but it should put you in a good position for points in the street class when the points are released. Finish first overall (all 3 days) for the class and theres a good prize.
talk to Pez about the discs.
Send me some info on this shit box rally that you always talk about. I like shit boxes ANNDDDD Rally!!!!!!
shitboxes are awesome
the rally website will tell you all about it:
http://www.shitboxrally.com.au/
and if you're feeling generous here's the fundraising page for our team :banana:
http://www.everydayhero.com.au/von_trapp_family_shaggers
fatz you monkey. how on earth did you convince 3400 people to give you a dollar. or was it 1700 people at $2. lol.
nice one mate. I might even give you a buck to send you on your way.
any word on the shitbox you plan to run?
Hang on a sec there big boy,,,thats no shitbox,,,or are you talking about the white one parked near the kiddies playground?.
Here's a vid of me in the Handley mobile,,,no thrashing,,,just wanted to check out Jenna's rear end.
Oh isn't there a heap of room on the bonnet for some nice person to sponsor him!!!
Cheers
Neil.
Here is my session #2.
Ended early with a jammed throttle cable, managed to get it back to 2nd gear and ride the brakes the whole way in, thanks to Neil for helping me diagnose the problem.
Here's a video of a few laps in the MX5. Best time was 1:20.5 which isn't bad considering it's absolutely bone stock. You can really hear the street bridgestones complaining on some of the corners.
Nice burnout Dunc!
check it 1k worth of love
that's my old car! filename is accurate, but i'm hurt by that big sticker on the passenger door :)
still got the redtop in it? jap dash? that was a while ago now..
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
