Haha no not retreads.
Fair enough if you have spent the dollars on a new setup...what are they???? :)
Weds SA90 :)
They just off getting some colour change love!
And Snowys old Tien's to go in as well.
  • Replies 136
Posted Images
LOTS of dish with the offset I have (there is a pic on my FB mobile uploads if you wanna see from a couple months ago) :)
I hate TE37's TBH. Every one has them! Took 8-9 months to find a set of SA90's (Via everyone friend @ Import Monster). Was looking for them before i even owned a GTR lol.
First track day for me, is a MotoX style helmet ok? also anything else I need to make sure to bring? so I don't miss out after a 2.5 hour drive :P
Can I renew cams license on the day?
-Leigh
-Leigh
moto helmet is fine. Wipe the mud off first :)
Bring extra pads, brake fluid, oil, tools, jack, fire extiguisher mounted well!
Jerry can of fuel. You'll prob go through more than half a tank.
Can't do cams at winton I don't think.
Thanks for the quick reply :thumbsup: will try and organize all this.
Should I be overfilling my engine a bit with oil? (only just had 100k service at racepace so most things should be ok)
Can anyone tell me more info about renewing CAMS?
You may have left it late to renew CAMS, it generally takes 10 days to fully process. You won't be able to renew on the day, though check with wrx club. [email protected]
Prob have to sign up for AASA if you can't get CAMS through...You can do that at Winton. Or drop into CAMS in caulfield? Though that may cost extra $$$.
The motoX helmet will need AS1698 or greater sticker on it (SNELL or FIA as well).
If you want cams and have time go into their office in malvern (i think it's malvern)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
