Hi all,
I went to see a reputable performance joint yesterday about installing a HKS 2835 Pro S kit I have got my hands on. I already have a 3" metal intake to the Z32 afm and then pod.
However, the new turbo has a 4" intake and the tuner is strongly recommending I move the afm to the cooler piping and run a 4" intake due to reversion and potential stalling issues arising when transitioning on/off boost. He said this seems to occur frequently with the larger compressor covers.
I want to keep my 3" metal intake and leave the afm in the factory location. Even though the turbo has a 4" intake its not designed for huge power (280rwkw max) and from what I can see all the other guys running this turbo dont run 4" intakes.
Has anyone had this issue? Or is it minor, the extra price of this work is scaring me off changing to this turbo.
just run a 4"-3" reducer, install the kit and be happy :)
That was my original plan, I hadnt even heard of anyone else doing that on this turbo. Do you have experience with this configuration or just everyone else's results?
not a problem even with an atmo bov fitted, but my HKS2835pros has a 3" intake and surge slots
oh wow yours has a 3" intake as well!! Mine has surge slots too but is definitely 4".
Joeyjoe's turbo has a 3" intake as well. I wonder why mine is 4"??
Think about how much air is going through the turbo on idle...... Next to none. 3" pipe will be fine. They supply a 3 inch pipe and reducer for a reason. Never heard of any issues
What size intake does yours have? Yours is the KAI version right?
Put the turbo in and see if you have any dramas before deciding to do the extra work?
We always do the 3076s with 3" hard piping and 3-4" reducer at the turbo and never have any problems. The factory arrangement should provide enough air mass not to disturb the AFM if/when the compressor surges.
Different turbos have different flow characteristics though. I say just give it a shot first then tackle the problem IF it arises.
From memory there are two versions of the GT Pro S compressor housing and both are port shrouded . The main difference is that one has a 100mm inlet snout and the other is 90mm with a separate machined boss fitted .
If you have the 100mm version I'd say the way to go would be a reasonable section of 100mm bore hose to let the PS'd comp housing do its thing then reduce to 80mm to suit the Z32 meter .
If tuning isn't a problem you could consider fitting the element and electronics into a 90mm AFM body making the difference only 10mm . 90mm is 3.543 inches and I reckon at 1mm over 3.5" you could stretch something to fit .
A .
reducer on the turbo will be fine. just make sure theres a bend and as much length as possible between the afm and turbo
I have just finished a custom 3" intake (90 deg bend) with the bov return and breather hose fittings for the current turbo and I do get the issue on my current turbo so I am thinking it might get worse.
Great to hear with your personal experience with the 3076s, thats great info.
That was my third option, 1. keep current turbo, 2. install new turbo and relocate afm, 3. install current turbo with reducer and see how it is
The only cost that I would double up on would be the tuning.
A .
Bugger I have just finished a custom 3" 90 degree bend with the bov return and the breather fitting. Ended up being a fair bit of work.
Interesting idea with the larger AFM body. I was trying to stay on the beaten path though :)
Nengun says the two sizes are 80mm and 100mm:
http://www.nengun.com/hks/turbine-gt2835-pro-s
Although I trust you disco more than nengun!
Do you know the reasoning behind the larger intake? It seems funny for a turbo designed for a standard engine to require such modifications.
Mine is the KAI yes and has a 3" inlet on the turbo. Not the 4" like the pro s
The pro s kits come with a 4" to 3" reducer and a 3" hard intake pipe
See thats the thing all the people on here that I have spoken to with the Pro S (joeyjoejoe, 75coupe and others) all have the 3" intake.
Are you sure the Pro S kits came with a 4" to 3" reducer at the turbo? As far as I know the Pro S kits have been discontinued and only the KAI is still made.
Pro s kits came with a 3" to 4" reducer. The one I saw this reducer was black unlike the rest of the hoses which are purple.
They have a 3" hard pipe which is identical to the one supplie with the KAI kit. No need for the reducer with the KAI as it's 3" turbo housing to 3" pipe
Dave I will post the id number up when I get home.
89CAL, that is promising! Although I am just trying to point out that not all Pro S turbos have a 4" intake. There are two versions, 80mm and 100mm.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
