Hi there, bought an R33 GTR a while back but never checked gear changes at high speed. There is a crunch when changing from 4th to 5th above around 130kmh, especially under load. Apparently this is a common problem to check with these cars :( What I'm wondering is- what does this mean for the health of the gearbox? Otherwise it seems fine.
https://www.sau.com.au/forums/topic/356949-r33-gtr-gearbox-4th-to-5th-crunch/
Redline lightweight shockproof gearbox oil.
Get some off Harold from PerformanceHub on eBay.
Mate had exact same problem, the above fixed his.
Not cheap, approx 120ish?? for the oil, but definitely worth it, don't skimp on cheap shit.
Mate had exact same problem, the above masked his.
FYP ;)
You'll find just about all boxes will if you try too fast of a gear change. Same with my RB25 box in my 31 and the GTR.
4th to 5th demands you be a little slower I've found for whatever reason. It is the smallest gear too remember.
Doesn't do it if you just give it that half second longer.
Thanks for the feedback guys; hadn't logged on since I posted sorry. Sounds like I should just take it a bit easy on the 4th to 5th- it's not like it doesn't go fast enough in 4th. I'll try and get my hands on some of this high quality gear oil in the mean time. Are you saying that even with the right oil and a lack of abuse it may still crunch a little if changed too fast, in which case there may be nothing wrong?
Redline! Do it and report back.
  • 3 weeks later...
Sorry if I'm hijacking the topic. I experience crunching from 3rd to 4th on high rev (e.g. 7000rpm). It does go in but you can hear the crunching noise. However, this only happens on load and never when I shift below 6000rpm. <BR><BR>Another problem which happened ages ago and only once was grinding noise when engaged in reverse gear after a drag day. A quick summary of what happened that day was 3x 6000-7000rpm launches and grinding starts. Drove the car nicely and after that day, the sound went away. Might be something loose from heat expansion? <BR><BR>I know its a million dollar question but if it was you, would you rebuild the gearbox or would you just try using redline? I am planning to change the clutch if that helps making the decision. Rebuild by my mechanic was quoted around 1.5k - 1.8k (everything included except for buying the clutch)
Redline is costing me $120 delivered from Harold @ performance hub.
Give it a go first. If it fails to fix it (I doubt it from what you're describing..), then rebuild/buy another, fill with redline from get go.
With the reverse thing, it could be the clutch cable stretching, making the friction point move to the floor and beyond? This happened with my M3 after a hard day out. New cable, $20 and it was sorted.
Edited by Ten Four
I have the same problem but with 3rd sometime's and 4th more often. I tried the redline oil and it still has the problem.
I'm planing on replacing the synchro's so does anybody know of a good place to get these or someone that sells rebuild kits?
clutch cable - ummm, no
I had an occasional crunch into 5th even when changing at a casual rate also the odd crunch on fast changes into other gears. I put in Redline Shockproof Light and it pretty much all went away. It crunched once into 5th soon after putting it in but not again for the last 3-4,000kM. Occasionally I feel a slight grab into one of the other gears, but not a crunch. For my g/box and hip pocket Redline Shockproof Light was the answer.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
