I am in Auckland,NZ and very keen on a set of these.
I have front camber/castor arms as well as the rear bolts and BC Gold coilovers, but it's still a boat in the corners.
It would be great to get some control with these.
Edited by nz_monkey
Daleo's bracing, and the Superpro compression bushes give a much more pronounced handling improvement than the sways imo. Not saying 'don't get em' but increasing the spring rate isn't going to improve the ride much, quite the opposite. I would be doing the lot...
Oh, I have. :P
  • Like 3
These are currently not a stock item with Whiteline, but this too, is hopefully going to change soon.
I have shipped bars to NZ, generally my prices are better even once shipping is included.
I'm on the case with this, I'll keep you posted.
  • Like 1
  • 3 months later...
I have been chasing for months now; and they have basically told me that there are no plans to re-introduce them.
I presented a case to support their requirement of a minimum order, that I felt I could guarantee, but no.
I even told them that Superpro/Fulcrum are doing a bar set now; but they don't appear interested.
I have lost my direct contact in R&D, and my supplier doesn't get the kind of detail regarding supply that he used to receive either.
I'm sorry guys; I tried. I really tried.
You could go to Fulcrum, but I have no way to get good prices on their product, and they keep no stock; EVERYTHING is made to order, with a minimum 6-8 week lead time.
Thanks for trying for us Dale. For everyone looking for bars I grabbed a set of Superpro from ebay (from these guys: http://stores.ebay.com.au/Online-Performance-Autos). They took about two weeks to get them too me, was advised straight away about the delay. Haven't fitted them yet, cars in getting some work done.
Cheers
Cam
Hey Dale,
No problem, thank you for trying your hardest best. You shouldn't feel bad about it. I just upgraded my swaybar mount bushes until I find some bars. Cheers Sonny
Edited by M35
SuperPro (I assume) on eBay at the moment:
Fronts (AU $238.50) - NISSAN STAGEA M35 AWD - 2001-2007 Front 33mm HD Blade Adjustable Sway Bar
http://www.ebay.com.au/itm/191272490435
Rears (AU $214.65) - NISSAN STAGEA M35 AWD 2001-2007 Rear 20mm HD Blade Adjustable Sway Bar Swaybar
http://www.ebay.com.au/itm/360995089393
Would need to confirm if they come with new mount bushes too...I again assume they would.
  • 4 months later...
Hi All,
Just to confirm and somewhat summarise this post from its beginnings...
What is currently the best available option for upgrading the suspension to stop the Stageas handling like a boat?
Have recently bought my 2001 Stagea (NM35) 250T RS Four and would like to sort it early next year.
Regards,
Toby
SuperPro is basically your only option in Australia now, Whiteline no longer manufacture bars for the NM35; and are not interested in reassessing that decision.
Lol... Rare!
Dale, ages ago, we did a group buy. I think it was selbeys or someone attached to that name? That's what I've got. Anyway, would that be an avenue for people wanting bars to explore again, or they out of business now?
Alex, Todd Selby was the guy I used, his business is Signature Swaybars.
He's still in business, but he moved down the South Coast.
The issue will be price IMO; he was around $300 per bar, and I'd imagine that will have increased in the meantime.
For the same money you could do the SuperPro bars. Maybe Scotty will chime in; I know he does a fair bit of trade with them nowadays; perhaps a group buy or bulk order could be placed?
I know they only manufacture to order; they don't keep stock on the shelf.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
