  • Replies 184
Posted Images
spent some time this afternoon on the car, hooked up the PLX wideband sender and guage as a temp item to test it out and check the idle AFR's
hooked up the datalogit and started it up
other than not sitting in the pfc's normal idle cell of 2x2 it was sitting at 11:1 AFR, so i tweaked it enough to run 14.6- 15.5 range - Then it was still hunting badly at 65 deg water temps, so i initialised the unit and ran through the 30 min idle learning - its is better now but will still hunt after you blip the throttle then settles down and stops it after 10-15 seconds.
so atleast i wont be killing the new 100cell cat from running stupid rich on idle.
waiting for a 52mm guage holder to arrive in the mail so i can mount the display and then go for a drive.
also been looking around for a way to mount a female USB port onto the dash area beside the glovebox, so i dont need to have the SM-AFR and the Datalogit boxes exposed in the glove box.. still havent found any product that will allow me to panel mount a female USB port so if anyone has ideas i'd be happy to hear it.
figured out the idle finally lol
ran through the DIY's for AAC and IAC cleaning, scrubbing them both out.
turns out the spring in the IAC (under plenum) that tensions the plate was in 2 pieces :P swap it out with a GTR one i had for the new motor and it seems to be fixed. cold start idle is 1200, but cant let it warm up until the sealant dries.
super cool idea with the usb chargers and the usb plug for the datalogit. lol I can see you are addicted to the dimple punch dies!! you'll be dimple punching everything for a while. it is a cool effect though. :)
Cheers Richard, I'm surprised no one else has done it.
Car is idling normally now, so that's awesome. It was another thing that's been annoying me for years. cleaned the AAC a few times but never looked into the IAC.
  • 3 weeks later...
still no speedo sender :( hopefully soon though, its been ages.
had to drive the car today, and im uber dissapoint with the tune on it :( ramping onto boost in 2nd from a T intersection was seeing 10:1 AFR's which would be a big contributer to the lag im seeing.
options are a retune and see how better it can get, OR a 0.61 housing from the 0.86 and then a retune.
option 2 is another $450 though
Do you want super responsive, or more mid to high end power?
What the hell do you have on the car that is coming on at over 4K?
I think you need to take the car to a magician and have them tune it... I thought you had like a 3082 or something?
huh? what?
hks 3040 0.87 rear AR
comes on same rpm as a GT30R with a 0.61 on another std rb25
In boxes on my shelves lol
Crazy busy working 6-7 days a week up to 12 hours so no time to play cars really.
Going to QLD next week so will be while for updates, see what I can squeeze out.
Must finish welding up my remote header tank and mount that this week too
Been learning to use auto cad 2012 aswell as I have access to a cnc plasma table now, so can hopefully run some sneaky nests in there for tow hooks and my brake caliper brackets
so much doing, getting nothing done lol
Header tanks, ooooooooooooooo
What type of setup are you gonna do? Just a normal type?
Is it ok if I try and catch you before you go away for the cover? No biggy if your busy I just may be out there later this week.
Holidays........I remember them :(
Yeh it can get like that with stupid work. Always interfering with car stuff.
QLD hey? Dont bring anymore cold with you, its bad enough with this lack of heat lately.
You should have a play with solidworks too. They are both great programs. But I love the modeling in solidworks.
Damn those USB ports turned out awesome!
yeah cheers
hopefully i can finish the paint work on the centre/shifter surround and get them finished off. that will be the true test
yeah mate, whitsundays - i hope i dont bring the cold up there - but im pasty white atm so i wont be sunning myself too much lol
yeah seen the posts about solid works, i think i should stick to 2D for now, cad 2012 i think does 3D now but i havent tried lol
They sure did! However, they dont make the car go faster....
one of them will, indirectly
just after that short drive there is so much light load potential left in it, that will make the car much quicker on the street
well i hope so haha
Dave, i'll call you tomorrowe
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
