Was at Gold Coast autosalon all weekend, was absolutely awesome!!
Took home Most Creative Conversion trophy and Most Powerful V8 trophy and autosalon magazine are going to do a feature on it :laugh: Cheering, bring on winternats!!
Edited by NA_R33
  • Replies 390
Posted Images
  • 3 weeks later...
no luck dude, gonna call a mate that works at nissan and investigate the possibility of a brand new crate engine. but that means big dollars... but i have a few major sponsors lined up so ill just have to take it as it comes.
infiniti usa sells them for about $4500 USD OUCH :ermm:
  • 4 weeks later...
Cheers dude, its in the back of the latest issue of zoom issue 100, but the proper feature will be in issue 103 so im told.
Yep , just got my copy of ZOOM issue 103 , and there it is . Good stuff .
awesome don, is it out in the new agents or are u a subscriber? i havent been able to find it..
update on the car, injectors arrived friday, 3 more bosch 044 pumps will be here end of the week, sticking the CF/fiberglass bonnet back on with Dzus Clips, methanol conversion and tune should be completed in the next few weeks along with a complete alloy dash, the it will be back to the strip to go for sick and get a whole heap of testing done before the nationals in september...
Also i hear a rumor that there may be a class for it at jamboree this year :no: neone else heard any more??
yep
bought it today - first time ive ever bought a zoom mag
good article too
car looks sexier in the 'flesh' ie bigger better pics
those Drift R rims make it look sexy
ps - going to wind the wick up on the 'charger soon? and NOS? could make a 10 sec pass nicely :(
  • 3 weeks later...
Just a quick update on the car guys, still running ~10-11 psi, 1600cc Methanol injectors magnaflow 750 pump, and a new tune we've turned out over 500hp at the treads... time to take it back to the strip and see how it go's....
Guys are you aware that Nizpro is running the VK56DE in their race boats? I have a short video of a web site that shows a VK56DE with twin turbos given a serious belting. Pretty sure you can purchase it from Nizpro.
If i could find someone to buy all my running gear (motor, gearbox, pfc, are ic, etc) I would get a VH45DE installed in my R33 aswell.
if its the same one i have seen it is of a VH45DE with twins strapped to the side of it..
I continually hear rumours of these super high power VH and VK engines floating about, but am still yet too find any hard evidence of them actually existing... Im basically learning everything from my own R n D, The only others i am aware of are all in the build process still and are not yet running. I may infact give nizpro a call today...
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
