Was at Gold Coast autosalon all weekend, was absolutely awesome!!
Took home Most Creative Conversion trophy and Most Powerful V8 trophy and autosalon magazine are going to do a feature on it :laugh: Cheering, bring on winternats!!
Edited by NA_R33
  • Replies 390
Posted Images
  • 3 weeks later...
no luck dude, gonna call a mate that works at nissan and investigate the possibility of a brand new crate engine. but that means big dollars... but i have a few major sponsors lined up so ill just have to take it as it comes.
infiniti usa sells them for about $4500 USD OUCH :ermm:
  • 4 weeks later...
Cheers dude, its in the back of the latest issue of zoom issue 100, but the proper feature will be in issue 103 so im told.
Yep , just got my copy of ZOOM issue 103 , and there it is . Good stuff .
awesome don, is it out in the new agents or are u a subscriber? i havent been able to find it..
update on the car, injectors arrived friday, 3 more bosch 044 pumps will be here end of the week, sticking the CF/fiberglass bonnet back on with Dzus Clips, methanol conversion and tune should be completed in the next few weeks along with a complete alloy dash, the it will be back to the strip to go for sick and get a whole heap of testing done before the nationals in september...
Also i hear a rumor that there may be a class for it at jamboree this year :no: neone else heard any more??
yep
bought it today - first time ive ever bought a zoom mag
good article too
car looks sexier in the 'flesh' ie bigger better pics
those Drift R rims make it look sexy
ps - going to wind the wick up on the 'charger soon? and NOS? could make a 10 sec pass nicely :(
  • 3 weeks later...
Just a quick update on the car guys, still running ~10-11 psi, 1600cc Methanol injectors magnaflow 750 pump, and a new tune we've turned out over 500hp at the treads... time to take it back to the strip and see how it go's....
Guys are you aware that Nizpro is running the VK56DE in their race boats? I have a short video of a web site that shows a VK56DE with twin turbos given a serious belting. Pretty sure you can purchase it from Nizpro.
If i could find someone to buy all my running gear (motor, gearbox, pfc, are ic, etc) I would get a VH45DE installed in my R33 aswell.
if its the same one i have seen it is of a VH45DE with twins strapped to the side of it..
I continually hear rumours of these super high power VH and VK engines floating about, but am still yet too find any hard evidence of them actually existing... Im basically learning everything from my own R n D, The only others i am aware of are all in the build process still and are not yet running. I may infact give nizpro a call today...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
