100% bolt on kit for an RB25 for a smaller kinugawa turbo than what simon is running would be the goods.... IF you can keep the price down
You would need to beat Hypergear if you wanted to get anywhere.
He is doing turbos that bolt into factory RB25 location and even use the factory style dump pipe that will give a no nonsense responsive 250rwkw for well within the states price bracket. He also does the same sort of arrangement with 300rwkw capability without too much of a compromise to the much more expensive garrett 3076.
If you do not want to run at a loss you will need to study his thread, R&D that he has put forward to date and the constant trial and error is what has put him in the position he is today.
GL
Yeah a TD06L2 8cm rear which was bolt on and internally gated would be a winner...
But I very much doubt that is going to happen!
I do know that they plan to produce RB25 bolt-on turbo's as they have just purchased an engine to test fit on ect.
  • 1 month later...
I would also be very much interested in a bolt on solution for the RB25.
From what Kamak has in store, it should not take them too long.
If they would come up with a dump-pipe or something that connects to the RB-25 downpipe
the case would be closed.
I found this one interesting:
http://cgi.ebay.com.au/Kinugawa-Turbocharger-3-Nissan-RB25DET-R33-TD06H-20G-/280666189186?pt=AU_Car_Parts_Accessories&hash=item4159022d82
I sent an EMail to Kamak already, no reply yet.
Was just about to post the same thing lol
But how about some bolt on turbos for a twin turbo 1JZ....Now there is a niche market, I would def grab a set if the price was right.
There are thousands of Soarers out there, and most owners want a stock looking engine bay rather than a big high mount.
The last set of aftermarket bolt ons were by HKS (T3G's), and they stopped making them 10+years ago
From what I saw in their catalogue they have all kind of bolt on turbos for Evos and other cars.
http://www.kamakdynamics.com/catalog/KAMAK_CATALOG_2011.pdf
But for some reason the Skyline is missing ..
Btw.
I was almost buying a Soarer back in the days, but decided to go for the Skyline.
(Though the Soarer's engine was smooth as silk)
In addition I wanted the V8's package and the twin turbo, and that was hard to find.
Cheers from London ..
Btw.
yeah the GT-T L Is pretty hard to find...mine has most of the options but isnt a L - Package
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
