thanks to Dale's effort in getting me the swaybars etc i've now got them in but im going to have to spend some time tweaking it, although its nice and firm ive had to back the shock's down and now i think im goin to have bigger prolblems with bottoming out in dips etc.
ahwell thats the fun part i guess trying to find the settings to make it handle nice allround.
  • 4 weeks later...
not much to update atm but i am getting my rims repaired after an altercation with a roundabout island which i lost LOL i swear it jumped out at me
and still waiting on my new bonnet and rear chassis brace.
still wondering if i should bother putting the F-con in yet.......... it would help because i am getting a fair bit of overfueling especially seeing at the BOV is venting to astmosphere and on gear change / lift of throttle i get some good backfires :)
Nice one! Let me know how you go!
My harness is on its way back and I'll be getting it tuned as soon as my EVC6 turns up... Want to replace the factory solenoid before tuning.
Here we go current mod's to date.
Power Duct and BMC Airfilter, Scotty's Dump Pipe, Fully Custom 3" Stainless Steel Xforce Exhaust, Phenolic Intake Spacer, HDi Intercooler, Turbosmart Dual port BOV, Dale's custom 2.5" Sutcion Pipe and Scotty's Wastegate Actuator.
Weird graph with the converter locking up on the original run and staying locked up after, did you cut any wires or is that a result of playing with settings?
How does she drive anyway? I'm sure you feel the torque drop off after 5k... Time for a highflow? :whistling:
still need to find out why im dropping off on boost, its ever since i changed all the vacuum hoses ahwell im happy any way might save the turbo a bit longer
Boost will always drop off a little due to the pressure in the manifold skyrocketing and blowing the puck open, the spring only helps so much. Do you have a controller?
the graphs are different at the bottom due to different throttle application.
we disconnected the manual boost T and are running it straight from the BOV to the Wastegate.
its a bit hard to describe but u can feel the extra power but overall the car is alot tamer than before, its very strong down low and very driveable on the freeway.
the car just sounds healthier has a nice crisp note to it now and damn does that suction pipe make some noise!!!
the cars just so different to drive i'll have to see how it goes over the next few weeks (mainly only use it on the weekend)
anyways just finished mounting the computer in the dash so gonna go out and drive it!!!!!!
ohh and no i havent got any extra sensor's they'll go on once i do the highflow etc etc
i'll probly only get the map/temp sensor and look into wiring up a EGT.
Nice Theo.
Glad you find it nice and smooth to drive. You'll have some fun at the drags I think. A programmable boost controller will take care of that drop off. Does the ECU have that function?
Are you still running off the AFM sensor? What Volts did you get up to?
Did you get a chance to over lay with my 3rd gear pull?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
