I don't what's funnier, the fact this bloke wants to put a turbo guage on his NA, or the fact he thinks lighting it up is actually going to do something to his car!!
My mate did this with an old boost guage I gave him, just for the Lol's.
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
