What might I be doing here?
I borrowed Fix Me Garage's guard roller to get my shit sorted before the coilovers arrived ... I hate these rollers! take forever to setup :lol:
Only managed to get the fronts done today until my back said no more ... I'll sort the rears out tomorrow.
Oh, I got a phone call today from Ryda, they were letting me know that the JVC headunit I ordered wasn't in stock ... thanks for letting me know 4 days after the order was placed. So I'm going for some poineer gear instead.
I recieved a hard intake pipe on Wensday designed for a Skyrine ... I'll need to do a few little things before I can fit it though.
So, this weekend was packed. I went to Ryda to sort out my headunit/speaker issues. I opted for a new model Poineer headunit with iPhone connectivity and some 3 way splits ... all for under $350.
Then we had a gathering at my joint until Twilight drift. I'm starting to get used to the car now, and I can see what needs improvements ... the shitty 195's have got to go!
Check out this vid that Tiksie made, great job man
http://vimeo.com/21546249
So, this week should be pretty big. My coilovers should be here which means the Stagea will be riding nice on low on some fresh wheels. Hopefully I can get the seat rails and other little bits sorted too!
On another note, it looks like the MX-5 is going to a new home very soon.
Edited by RoadsterGarage
i know that my greddy's are 8 and 6.....so i think they should be fine.
it all depends on the type of suspension and the weight of the car.
my ls400 with double wishbones had 24kg fronts and 12kg rears.
Also with springs people, the "stiffness" also comes down to spring construction, if you drive on some good quality springs, with the same struts (IE if you used the BC springs and then used swift springs) you would find the swift springs would feel softer and forgiving, yet have the same weight/displacement, and better performance. (another difference between your cheap BC/HSD/JIC and quality suspension)
When will you be taking it off the "kid-pan" and getting some real drifting in?
Whilst not arguing your point about spring quality, the spring weight "number" that people are quoting; is just a measurement of how many kilograms of force is required to compress the spring a certain distance in cm or mm.
As for quality, there are definitely different grades of spring steel, and also country of origin has a part to play (Chinese; generally garbage in consistency & uniformity) and whether progressively wound (tightly wound at one end and looser at the other) or linear, definitely changes the "feel" and behaviour of a spring.
Also regarding the percieved "quality" of BC's etc; I've been using BC's for over a year now, the damper rates and spring rates are well matched, the construction, finish of machining and coatings is excellent, and there are numerous threads on other forums of specialists who've pulled them down to inspect their internals and they've come away impressed.
While I'm not suggesting that they're comparable to the icons like Ohlins, Drummond and others, they are also vastly different in price. There's little justification for using such an expensive product in a "Street" car, and although people do (which I have no problem with) I think it's a mistake to look down on so called "budget" set ups, just because they don't have a premium name.
For the money you pay for BC's; you'd struggle to buy better without another thousand dollars, IMO.
Oh, and Lol @ "Kid-pan"; that's where I'd be...
Edited by Daleo
+1 :thumbsup:
I agree Daleo, my setup feels much better than the Bilstein/Tein etc. I have tried. More supple, yet firmer. It was quite interesting to see such quality coming out of Taiwan and they seem to be lasting quite well.
I try to never bag anything I haven't tested personally.
Your quiet right Daleo,
I have tried a hundred set up's and you will always get what you paid for, I liked Tien Mono flex as far as bang for buck went, (not what other people would call cheap, but they are much better than BC's, and only ~$1100 (i realise that is double the price..) but I found my Bilstein coil overs to be very nice, and the dampers are much closer matched than many other's, (They may not have damper adjustability, but cheaper coil overs are far front equal across all four)
But in the end, it's a street car, so spending big money on suspension that will never get the beating they deserve is like buying a 911 and never driving it.
I'm aware of that, I didn't feel the need to go into so much detail so cool.
FYI I've had alot of setups, and I've found BC to be at the top in terms of bang for buck, unless your going all out with Teins for example (i.e flex/mono flex) I'd be getting some BC's. f**k, even my shitty G4's overshadowed my Tein superstreets ...
what, so I can do something like this?
:whistling:
The car is stock man, I'm not expecting miracles from it, I'll get there though. It's all fun at the end of the day .
whats with all the anger and crap in the stagea section in the last few days??
Good drifting pics man, can't imagine how hard it would be to handle the stag when sliding, i've had mine 4 wheel sliding a couple of times and it doesn't feel awesome.
oh and while we're "pulling dicks" with drift pics, heres mine
:nyaanyaa: :nyaanyaa: :nyaanyaa: :nyaanyaa:
Edited by Big Fella
If we pulling dicks with drifting photos, any Oran park shots or videos? :thumbsup: Hehe..
Nope, I started getting into it a few years ago, which is a shame I would of loved to hit up Oran park :(
I do have shitloads of vids on youtube though.
You can pull my dick all you want, I couldn't give a f**k what you think :thumbsup:
    • Hmm makes things tricky then.  I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.  But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.  If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?  Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
    • Ok so I will not defend my naivety. I regularly feel like things look easier than they are.  As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
    • If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.  I've seen professional welders do similar but easier repairs and still end up with warped panels.  It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.  Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.  Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
    • I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.  I'd prefer some ugly metal fab than anything weak.  I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
    • Ok, thats a good starting point.  So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right? Before we look at other options, how confident are you welding?
