My old ceffy had hicas and i went through alot of trouble with front steering racks. I tried an s13 hicas rack and a s13 normal rack. In both cases the rack bolted up the same but the lines were totally different. In the end i ended up getting my old rack rebuilt
  • Replies 155
Rip out the hicas, then you can use a non-hicas S13 rack.
Fabricating new lines is easy, pay somebody.
Yep, You could possibly swap the housings over too if you really wanted, might as well chuck a rebuild kit through it at the same time though.
I think I've asked before but the answer was vague, I need a definite working solution for handbrake cables. I have a manual centre console and mounted handbrake in my laurel, I need to know what legs (front section of cables that split to 2 off the handbrake lever) and rear cables to use on my laurel. Has s14 rear hubs. Seeming as finding original ones are rare as rocking horse shit. Dunno why I threw away my old 4 stud hubs when I was cleaning my old place to rent -__-'
  • 1 month later...
  • 3 months later...
  • 3 weeks later...
  • 3 weeks later...
ok got another question. I got a a31 rb20e auto but want to get a lsd because i keep on three wheeling and gets pretty annoying. could i use any other LSD diffs from a different car mine one is a 3x2 bolt pattern
are you sure its isn't just a loose r200 (lsd) and not a r180 ( open wheeler).
with my old lsd you could turn the direction of the shafts apart by hand.
skyline and silvia diffs will fit pending abs, backing cover swaps and front diff mount bushes for the s14/r33 and up models
Edited by Dan_J
its defentaly a open wheeler! dont want to do the cheap way and just weld the deiff up. but a good excuse to upgrade the diff to an lsd. its a non abs model. i heard that s13 and r32 diff bolts straight into a cefiro ? pretty sure the r32 can, but not quiet sure about the s13 diffs
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
