  • Replies 57
  • 1 month later...
I visited Johnny last month and won a bet. Johnny bet I could have a steer if I could get n and out of the zed cleanly. Much to his disappointment I fit in there nice and snug. It's a nice cockpit. Looking forward to a test drive soon!
Car is looking very serious now. It should be well up the point end. :)
Custom lightened flywheel (4.5kg) to suit 7 1/4 (184mm) twin plate motorsport clutch. This flywheel matches the VQ30DE with bell housing adapter and Z32 gearbox.
My link
  • 1 month later...
  • 1 month later...
After busting a head gasket at Superlap on the stock motor and finding it's limit, we are now bulding a tuff motor and increasing to 3.5 litre. Using Darton Sleave kit (closed deck) using VQ35HR head gaskets which are much better. This requires modifying the engines coolant flow and does away with the two rear thermostats, yes the VQ30DET runs three thermostats and high temp ones for emissions reasons, they open at 95 and 105C, crazy and not good for racing. We are using a VQ35 crank, modifying the block, forged rods and pistons. Whilst at it we have slightly ported and then polished them and domes. We relieved the dome to match the 95.5mm pistons up from 93mm. Also adding ARP main studs. We had everything Cryo treated.
  • 9 months later...
Pm'd about the adaptor
My link
  • 1 month later...
I was thinking about this.. you're making a vq30 a vq35 basically by swapping the internals. A vq35 head flows more and you could possibly fit the vq35 heads with some mods... but all that work to make a vq30 a 35 why not just buy a 35?
  • 4 months later...
  • 4 weeks later...
It's been a long while we haven't put an update for our Slot Car now with VQ35 & twin 3071 turbo's.
Here are the links for the latest updates.
http://www.uniqueautosports.com.au/PAGE15.htm
http://www.uniqueautosports.com.au/PAGE16.htm
  • 6 months later...
Here's the link to our new website.
http://www.uniqueautosports.com.au/gallery/project-unique-zed.aspx
Won't be going to WTAC this year, it's just out of our budget at the moment. We'll be there though helping and watching, keen as!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
