Not much achieved on the weekend, resprayed the radiator air deflector as it was flaking..... Replaced some dodgy bolts with nicer stainless items and cleaned up the 2 front A/C brackets, so much to do.........
The fuel cooler is setup from the return line to the cooler then to the surge tank.
Ahh ok cool, the same way i've done it then.
Is this the 'best' location for it?
Have any of you guys got a temp sensor in your fuel system somewhere? If so, where?
I'm putting one in mine, my idea was to have it in the return line just before the fuel cooler.
No temp sensor in mine at this stage, however i would love to be able to monitor it....
And yes i believe the location is the only spot for it, it is setup similar to the Z tune i think :)
I would put the sensor just before the fuel rail so you know what temperature the fuel is when it gets to the engine. Knowing what it is pre-cooler doesn't help much?
My reason for putting the temp sensor post fuel reg, in between the fuel cooler is this should theoretically be the hottest part of the fuel system?
I would imagine so, either location is still going to give you an indication if the fuel temps are rising.... I still find my surge tank getting hot which i dont think is normal, however everything is running optimal so i guess it is?
One thing i did learn is that the fuel cooler has ruined my normal jacking up procedure, if i jack the back first it makes the front too low, now if i jack the front first i get this -
LOL and yes that is a snap on super low jack already!
All good, will just have to change the way i do it!
And i broke another POS ISC arm in the rear, they flog out or break in no time! Garbage! So i replaced it with more cheap stuff for now until i can afford to do it properly -
GKTech make billet ones, no welds ;)
This will need to be my next purchase i think! I have now replaced the shitty ISC front caster rods with GKTECH arms and the car feels so much better! And they are so light too!
How is the tank plumbed from top to bottom?
There are 4x hoses that connect to the surge tank. All should be at different heights. But some tank are different.
Eg theres two ways to dot it.
From top to bottom;
1.
- Return to main tank
- Return from fuel rail
- Feed from main tank lift pump
- Feed to main pressure pump(s)
2.
Which way is yours done?
The 1st option heats the fuel as the surge tank has to be pressurised to return fuel to the main tank. The main pressure pump and the lift pump have to work harder to fully fill the surge tank allowing fuel to flow out of the top fitting back to the main tank.
You want a small air gap at the top of the surge tank with the return line back to the main tank jn between the return from the rail and the lift pump inlet.
If that makes sense?
I just double checked so i didnt get it completely wrong :P
Fuel tank to surge tank, feeds twin 044s to twin lines to each side of rail, center of rail returning via fuel reg to return line to surge tank over flow to fuel cooler into fuel tank, tank feeds surge.
Loving the build mate. Engine bay looks clean and stealthy...
Thanks mate! Makes it well worth it when not only do i get to enjoy the car BUT i get people appreciating the hard work and money etc that goes into such a build ;)
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
