This is the footage from our new Go Pro Hero 3, we were only learning to use it but we are happy with the image quality considering it was through a wet plastic lense!
Go Pro Vid is a No Go. :(
I'm starting to wonder under what circumstances this thing actually has traction.
Idle? :D
Its up and going now mate! It was 1GB file lol
Notice at 1.33 you can see someones screamer pipe that has fallen off :blink:
Make sure you switch it to 1080 HD
So before all of these vids came the Friday and Friday night, once again another epic effort from JEM to get me to the event but also a quick thanks to DVS JEZ which was kind enough to let me break down in his workshop for a while lol
So, the ECU was picking up an issue again and i was pissed off, the same sort of issue as before and i was ready to give up. So we checked the front fuel filter at Jez's and although it was dirty it was not blocked, Jez luckily had stock on hand so a new filter was added and i was on my way again. (Queue skids and Gate)...
Everything was sweet for a while then 40mins into the trip it started leaning out again, This made me wonder as everytime the car would play up it would be after around 35-40mins... We tried to combat this with fuel cooler and bigger fuel system which certainly helped BUT there was an underlying issue we hadnt found. I limp the car to JEM while watching the AFR's like a hawk, they were not great but for light cruise they were doing no harm.
Once at JEM the guru (Adam) jumped in the car and we went for a run with the laptop, he noticed it was lean accross the board and immediately said it was the injectors, this worried me as there is no way the shit was getting through the Ryco filters and to the injectors... We took them in for a flow test (AGAIN) and the results were not good, they were all around 1200cc with shitty spray patterns, while speaking to the injector guru he mentioned they were down on flow from last time and when we checked the previous results we found they were 1300-1400 last time... At that time it clicked that these were meant to be 1000cc XSPURT injectors, WHY were they giving those readings?
So the call was made and as a result we found we had been supplied the incorrect injectors from the beggining, side by side with the 1000s they looked identical and no way i would have picked it but due to the part number they were identified as a troublesome 1600cc injector (I think based on the indy blue style) and from there things started to make sense.
The guys were brilliant as always and immediately started working on a solution to the problem, we were able to make the choice of any injector and as i plan to keep the 34 for many years and push it too its limits etc SO there was no point staying with 1000s when we had the chance to go bigger, although the bigger injectors were much harder to fit and also not as easy to tune (Dont want to make Adams life too easy) i opted for the big boy 2000cc injectors which Dean was kind enough to use the new ones waiting to go in his own personal car just to get me going...
It was getting late arvo and the injectors were finally in and wired up, I am sure it had been a long farking day for the guys but due to the fact i had Powercruise booked they were not going to give up.... The car was strapped to the dyno and the tuning was ready to begin...
By this time it was night and i honestly thought i was leaving the car at JEM and getting a train home BUT Adam re-assured me i was going to powercruise and that it would be fine... Due to having a full flex setup we could not do a full tune as we would have been there forever BUT a thrasher tune was chosen just to get me going and the fun part began...
After running the car up and being pretty happy with the results and the fact the car made the power so easily it was time to make the trip home.... Initial thoughts were FAAAAAAAARK as the car left on full power, felt so good to get nailed in the seat again and have the AFR perfect, it was a long cruise home after a little fun on the way to get fuel :ph34r: and i was home just after midnight.... 5hrs later i was back up and showered AND the car was driven to the track, the car made it and was faultless all day, the rain made it pretty boring but to be able to enjoy the car and thrash trouble free was quite a good feeling!
We had planned in removing the smaller stickers etc and just run the bigger ones BUT after the night we had i CBF and just ran the car in the filthy spec you see above.
Whats next? Well as the car still needs a full retune it will likely get a better dump pipe at this stage! As much as id love to accidentally slap a GTX3576 on it, i would just be pushing the internals harder than they need to be pushed, remembering i have a 100% stock headgasket and bottom end... :D
More to come soon -
DVS JEZ - Gauge fitment and wiring
Suspension - New balljoints, bushes and bearings
Interior - New Handbrake etc
Paint - repair boot paint and tidy up appearance.
OK, so my plan has been delayed by house renovations BUT i need to get the beast going again... When i lose momentum i tend to lose motivation, yet the second i drive it again i cant wait to do more SO the plan is to get it happening! First on the list above was gauges so i started this morning -
They are a perfect fit and sit in with no assistance at all but i will make a bracket behind them to be safe. Then ill get it on Jezs hoist and get the gauges done, i cant get to the Greddy block so i need it up in the air, plus i am useless with all things wiring related :P
wow. gauges are a perfect fit. what brand/model are they? its hard to read anything on their faces because of the flash/glare lol.
Just cheap stepper motor gauges, they are Racetech i think.... Basically Defi copies! There are two types, basic gauge and then these ones that have adjustable warning buzzers and peak reading recall etc.... The reason i chased these ones down is that they were blue with red needles to match the rest of the dash :yes: You can have them lit up white or blue, this was white with the power on -
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
