  • Replies 804
:unsure: , i haven't had my 20 for a while, but from memory they should all stick the same amount out when you sit them in the holes. You can't really mess them up i think as they will bottom out, but seeing as you engine is in you might not be able to see properly
Sussed it I think, there are a couple which will only have about 10mm of thread engaged but most are between 15-20mm and I checked the long ones in the head to see how far they will go in before bottoming out :thumbsup:
Sweet, i'm still hunting down bits and pieces for my engine. Am changing builders for the engine, mate had some things happen that havent really impressed me with that workshop. Gona go back to old faithful i think
My very first car, bought with the money i've been saving. I think it's a pretty good car to learn on since i'm 17 haha :D, new front mount and boost gauge going in at the end of the month. :)
Looks nice, needs moar pics
Tidy! If anyone wants a searchable pdf copy of the 32 gtr workshop manual.. you can find it at the following link for a few days (until I need the space back :) ).
http://members.iinet.net.au/~psyko/car/gtr_32_service_manual_searchable.pdf
RB 20 engines make me angry. Made for Japanese people with small hands :(
Bah ridonkulous! Once you pull half the shit out of the bay you don't need and go high mount, you have enough room in there to dance around
I had 310hp with boost spike, unopened motor, gtr inj, ems and 6boobs mani, lasted 5yrs before i pulled it out for teh restoration. The 25 conversion is up to you really if you feel like you wana go that way. My old turbo setup is going onto a 25 in a 31. I was going to go down a stroked 25 route but changed my mind for the 26/30 which would have cost the same.
The 20 is a great base to play with they just love to rev
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
