Im starting to see it as a blessing because now if I crash it at Collie I won't be so disappointed if it gets destroyed.
How much did you pay for your gtr front bar Simon?
Can't remember, got it second hand... You are actually lucky, the lips are the expensive thing and you already have one. Generally they go really cheap second hand without a lip so get hunting :thumbsup:
  • Replies 804
Non VCT head? No unexpected leaks or anything? What did u do to overcome the problem with the breather fittings?
Yeah non-VCT head, only leak is from power steering pump (I think I levered on something I shouldn't have to tension the belt :blush:) and I went back to my stock covers with stock fittings.
Nobody know of anyone with a stock RB20 ecu that I could borrow or buy?
Or know of other ways to get a diagnostics code through a power fc?
Would be a maaaajor help to me ;)
Sorry, don't know much about pfc's :(
i know of a good workshop in melb that might help you over the phone, would you like their details?
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
