If anyone needs odds and bods for their 32 i'm stripping a 4 door atm for the interior. Theres no suspension components but i have front quarters, reo, abs unit and little bits. Or if you'd like the shell with some LHR damage come take it
Bah! why couldn't it have been a 2dr :P
  • Replies 804
thanks guys fresh forged motor going in as i speak !! take a look...
sard 700 cc injectors
brand new garret 2860-5 turbos with all new gaskets
hks exhaust gasket and tomei metal intake gaskets/throttle bodies
acl race series full engine bearing kit, along with king bearings unknown what they were for !
shim head gaskit race series (metal)
N1 water pump
tomei UMEDA oil pump
tomei 260 deg cams
custom built extended sump and pickup with trap door setup in sump (MADE BY RED R RACING )
rebuilt front diff and preload reset
engine balance
machine crankshaft
ross harmonic balencer
cp forged pistons, 30thou over size from original bore
eagle conrods
gates performace timing kit
replace crankshaft oil galleries with screw in plugs
deck block
recon head ,full set of valve guides,3 angle valve cut ,set of shim tappets to cams supplied
aftermarket valve springs
custom work (drill and weld up oil galleries in head advised by red r racing)
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
ARP Mains + Head Studs
All New Hoses And Gaskets
Oil Relocation Kit + Cooler
alloy Radiator
new clutch built by (JIM BERRY RACE CLUTCHES QLD)
Nismo Airflow Meters
New O2 Sensors
trust 600x300x120mm Intercooler,
recent full rebuild on gearbox
running the nistune ecu with nismo afms
and a blitz i colour elect boost controller
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
