Hello fellow Skyline Owners and members
i have R32 GTR , built forged motor , stock rebuilt turbos with steel wheels , turbos back exhaust , cooler piping n pod filters. car hopefully should be reliable having changed most seals gaskets and vitals such as oil pump water pump radiator. didnt change engine wiring loom =[
car runs stock ecu, afms , fuel pump rail injectors and regulator ... so its fairly stock as a rock 233kw atw @ 14psi -_- at the time of dyno run =/
not looking for turbo upgrades or pfc the car as yet , but working it up slowly whilst still keeping it drivable most of the time ....
thinking of putting a bosch 040 fuel pump -> i understand it will greatly improve overall system reliability/calability but will it gain power? and do i need a fuel regulator or injectors at the same time .... not as yet i think ? being so stocky
car also has boost tap -_- currently connected turbo side, where both wastegate signals turn to 1 line and go around the back or head .. is there a better position to put this?
heard there is a better way to hookup the boost tap ... and also removing the 'boost solenoid' ( mounted on a bracket behind factory battery ) apprently builds boost most efficently ???
thanks yoh
https://www.sau.com.au/forums/topic/358655-rb26-gaining-power/
fuel pump will add 0rwkw
why would it add power?
air and fuel make power, not much how much a pump can flow
change the air/fuel ratio, youll make power
ie tune will make more power
larger turbochargers will make more power
fuel pump is good insurance policy
and youll need it later on when you change turbochargers
std fuel reg is fine, dont change it
14psi with boost tap? remove restrictor from boost line and it'll run 15psi without anything else.
stock pump, injectors and fpr are good for upto 290rwkw.
what other mods have you got, ie exhaust, cam gears etc
there is plenty that can be done before the comp that will make a GTR alot more fun to drive
Its crying out for an ECU+tune. Nistune would be the best option. Dont bother with anything else until that's done.
If you want to go fuel pump, nismo or sard drop ins are the nicest but not the cheapest. If you're strapped for cash just enjoy the car as is.
so fuel pump is just for reassurance ... was thinking my pump might lack pressure at high rpm being so old =/ ??
any1 know about removing the boost solenoid ? apprently putting boost tap in place ??
theres a blitz access ecu 4 sale ..... terrible idea or ?? drove a gtr with this ecu , stock turbos, big cooler not bad =/
thanks dudes!
Fuel pump will add no more power, i've got walbro pumps in my GTR. they're smaller than the bosch ones and are good for 350rwkw
std fuel reg doesnt need changing ever! i've got mine still running 1000cc injectors with twin fuel pumps and e85. i dont understand why people get FPR's
IMO here is what you should do if you haven't done already
1. 3in exhaust at minimum, also look at upgrading front pipe
2. K&N air filter for airbox or pods
3. remove boost restrictor to run 14-15psi
this should get you up to 250kw
4. Upgrade ECU (Nistune is good value and i'm running it in my car)
this should get you 250-280kw
5. upgrade injectors to 660cc or more & fuel pump
with a tune you should be able to get around 300kw
at this level you'll be around the max of your turbos, you could choose to push them hard with AFM's but it gets pretty $$$ either Nismo's or Z32's
at this level you'll be around the max of your turbos, you could choose to push them hard with AFM's but it gets pretty $$ either Nismo's or Z32's
my car has apexi front pipes and 3 1/2 inch exhaust , apexi twin air filters powersomething i think its called.
boost restrictor is located where ? is that the boost solenoid located between battery and shocker tower? what do i do with both vacuum signals?
yeah fuel pump is not needed unless there is a problem with the one you have.
and if you do want to change it, get a nismo. much easier to install and very good pump.
then next step is power FC or nistune. both are excellent options and will really bring the car alive. when getting the nistune or power FC tune done, take the opportunity and get some adjustable cam gears fitted and have them adjusted too on the dyno (in conjunction with the ecu tune). forget the blitz access ecu. waste of time. they are pre-set for certain mods and cannot be changed. it may not even suit your cars state of tune at all.
thanks for advice
someplace is asking 320 for nis-tune board fitted ... how much will tuning cost me =/ ?? ( sorry if this is silly Q ) and where is the best place to take it in melbourne ?
pretty sure i will change fuel pump for peace of mind along, fuel filter and injector reco/clean wont go astray :) bosch 040 ? ( intank pump but pretty sure some bracket or somethings gota be made up for it right ? )
afew of u guys said cam gears should be put it ... ( hope my harmonic balancer comes off easy ) any1 have issues with cam adjustable cam gears that arnt HKS and arnt 200million bucks? some dude on northside sold some fair cheap, had them on his gtrs ... $100 or so =/
cheers dudes!
envy imports in sydney make their own cam gears. they use the outer gear of standard gears (very strong and doesn't wear) and add an adjustable alloy inner plate with 5 bolts. very good set-up and quite cheap. otherwise tomei are good and trust are good too. whatever you get, make sure they are done up tight when tuning is finished.
if you want intake fuel pump, get a nismo pump. a bit more expensive than a bosch but are 100% direct fit. even someone with the most basic mechanical experience could fit one DIY with basic tools.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
