cany find real info mation on this damn round about of a way site you wanna know my experience PM me all ill tell you REAL life engine touching blowing up fixing INFO
My head hurts when I try to read this!
On topic though...
The other benefit worth considering is that it takes longer to heat up a larger oil capacity. This is useful for sprints where your at consistantly high rpm and not necessarily getting a lot of airflow. Its been my experience that cooling systems dont work well until your above 80km/h (and in a tall gear, not in 2nd and 7000+ RPM, at full load). Below 80 your cooling is predominatly fan derived.
Im with Steveo with the higher flow and smaller restrictor option too. I like the idea that my bearings area getting plenty of oil flow to keep them cool. I also like that 7 litres of oil stays cleaner for longer compared to a smaller pump.
I know of 2 guys both using n1 pumps and over filled there sumps by 1 litre and still managed to smash there pumps. If money is not a concern I would go for the tomei pump for peace of mind as it has been proven that they can take alot more punishment and being based on a 2jz style of pump you don't hear of them having any problems.
Most of the failed N1 pumps I have seen are accompanied by an equally failed harmonic balancer. At 8000rpm, if you have even the slightest harmonic imbalance, you are going to hammer the living f**k out of that gear. They get larger, they cease to fit in the round hole they are designed to turn in and they start to grab, then they crack or break.
I have seen many people successfully run N1 pumps and standard capacity sumps at the track and not have a problem. I have seen guys with Tomei pumps at the track have problems. It works both ways and it's not always about having the absolute most oil flow you can possibly imagine and all your problems will just waft away. The fact is, the N1 pump flows enough to cope with any amateur type racing events, but is your oil up to the task?
If you are going to run the N1 pump, make sure you are using an extremely high pressure resistant oil that has a film strength higher than any other oil on the market - Royal Purple
It never hurts to have a larger sump capacity and it never hurts to have more flow, at the end of the day, fuel and oil are two of the most important things you need. Who really cares about cost? Another engine rebuild is going to cost you a frig load more.
Another fact is that the materials used to make the Nitto and Tomei pumps are much stronger than the material used to make the N1. They WILL handle more punishment and not break. They have a longer fatigue life due to the material they are made from.
It's the same as the forged conrod argumement - yes the factory rod can handle a shit tonne of hp, no it will not last forever. The fatigue life of a forged rod is much much much longer than the factory rod, and for $600-$800 for a set, why would you stuff around putting old (possibly tired) parts back into your new engine?
If it were me, and I was going to spend 2-3 days a year at the track and 80% of the time it will be a daily, I would leave the sump and put on the N1 pump. If I was going to be spending a day every 4-6 weeks at the track, I would invest the money into a Nitto item. They aren't that expensive and will take a hammering for years :thumbsup:
and +1 on overfilling the sump slightly (0.5 - 1L) at track events. But make sure you have a good catch can setup and check it every 5 laps or so if you can. You'll get to know what your car can handle once you have spent some time out and about
Obviously with added oil/larger sump the oil temps and similar are beneficial to the cause depending on use.
Snowman & Scotsman both ran stock sump'd GTR's for 2-3 years no problems in that department. Motors were stock too and eventually the died but that's what happens @ 330-360rwkw over a hard life. Since then they've both used N1 pumps, as have pretty much all Vic cars. Not one has broken a pump yet. Most motors hand together fine as well (failures are not pump related).
So if you are a bit worried then swap out the gearset. They aren't too expensive and if you get piece of mind then that's covered off.
Comes down to cost really:
Option 1 - 1500 Closer to $750 if savvy Billet gears from JPC.com.au $350 can be used
Option 1.5 - 2300
Option 2 - 3200-3500
I'd also suggest if you are going to go all out on a pump, that you use the Tomei one. It's the only one that utilises a different gearset arrangement similar to that of the 2JZ (never hear of them breaking pumps). It's something I've never really worked out why the other aftermarket pump makers don't use the Tomei/2J style as for a bolt-on pump, it's the way to go.
Thank you R31 Nismoid for the answer above its a very valuable and credable answer
Well said mate. The Nitto will save you the additional expense of having to pull your engine later when the other pump dies. Its the only pump on the market that has not suffered gear failure and each pump is assembled/clearanced checked by the engineer who designed it not some monkey on an assembly line.
you can get a tomei pump out of japan for freakin 1400bux these days, why would you even waste the time on a N1, i mean, you have already spent 6-9k on parts, machining costs, the time pulling it all out, whats the big deal with the extra bit of coin. its not really that much when you think of it, and when it comes down to it, its the rb's weakest link, so why not just put down alil more cash for peace of mind
This man speaks the truth.
I know you explicity excluded the dry sump option but it's worth considering an external oil pump with wet sump. Cost effective, and you can avoid the ^^ guys getting emotional over your oil pump choice.
People just spout a lot of what workshops feed them without knowing any better.
This made me laugh.
Nitto pump and collar, tomei sump baffles and an accusump... would have to be the best set up for the money and ease of fittment....
Otherwise, add a sump extension with pickup.
I wouldn't piss about with an N1 pump on a built engine... Saying that, I have an N1 pump (with no collar) on my thrasher rb25 and have had no problems yet- I do have an ATI ballencer though.
I'm not a massive fan of external oil pumps... the only thing that stops total failure is a thin little belt, with little or no guard...
J.
Pharkk, this turned into a pile of less than helpful vitriol.
The point of the thread was to get some determination on the relative merits of flow rates & sump volumes not to get all the monkeys chucking sh!t at each other.
I don’t want the worlds greatest anything for the sake of having it. It’s like having the worlds hardest clutch which will last forever but destroy three gearboxes during its life. Useless. The point is to get a well balanced set up that works harmoniously over the life of the motor which will, eventually, end up dead. Like they all do.
So far to the best of my understanding:
A stock pump will flow 47litres/minute at 6000rpm.
Various aftermarket pumps have claims to have greater flow rates.
The Tomei pump claims to be 20% higher in volume. To be honest I am not that enamoured with the three piece design.
The Jun pump is claimed to be 25% higher in volume.
The Nitto pump (going on their published figures) is 40% over stock however their number for the standard pump flow rate is lower than the one quoted everywhere else.
The downside of a higher flow rate is the need to have a much bigger sump volume, the knock on effects to the head in terms of getting rid of the oil, the pumping losses, the longer period needed to get the greater volume of oil up to a decent temperature.
The upside is it may give you better bearing life longer assuming you don’t get pump cavitation issues.
Oh and lastly there is nothing wrong with sintered metal. It is just a process used to form steel. Hell BMW used to use it for conrods.
Anyway if anyone can help out by way of confirming the Nitto Flow rates I would be grateful.
Do you mean this data from the website:
http://www.nitto.com.au/products/oilpump-RB.html?category=engineblock
Jun pump data is here:
http://www.rhdjapan.com/jun-high-flow-oil-pump-rb26dett-rb20det-rb25det-16702
Tomei information seems to be all over the place.
Data varies from 56-57 lt/min at 6000 or 7000 rpm depending on what supplier website your looking at.
Or were you chasing actual test data performed by an independant?
The data for Tomei was on volume 22 of new release information from Tomei in Seppoland. Put the flow rate for a stocker at 6000rpm at 47L/min & the Tomei pump at 56L/min.
I wasnt necessarilly looking for independent data just confirmation or otherwise of the Nitto flow rates as the listings they use for stock pumps is at a variance to everyone elses.
Edited by djr81
I wouldn't say the tomei pump uses a gear arrangement similar to the 2JZ style pump? 2jZ pump has a splined gear on the crank, driving the oil pump gear. the tomei pump as a 2 piece inner gear but it still uses the same 2 small flats to drive the pump gear just like any other 26 pump which is the weak point. the gears 'teeth' are slightly different but they are still a gerotor type pump just with much bigger gears with a more suitable material. they are unique in the 2 piece inner gear set-up but still no where near as good as a 2JZ pump. the best option for RB26 is still getting a set of splined gears made up with the inner gear permanently fixed to the crank.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
