Hey guys,
All has been going well in my Stagea's life (apart from the 4WD light coming on when it feels like it) until yesterday when my RX just stalled in the middle of a school zone! What was even more worrying afterwards was that it wouldn't start straight away - I had to crank it for 5 or 6 seconds for it to go again!
Anyway I thought this might have just been a once off, but later in the day I went to start it and there was the same issue, took about 10 seconds this time, and the ECU also threw a fault code: P0345 which is "Camshaft Position Sensor Circuit Malfunction Bank 2".
From researching on the American forums, other people with this fault code get the same symptoms as me, they replace both sensors just to be sure, and the problem is fixed. I've read that the code can be caused by other faults, but it would seem that most people just have a dud sensor, and infact there was a recall for '03 350z's in the states for this exact problem.
My only problem now is how would I go about sourcing the right part from my helpful local nissan dealership? Is there anyway of finding or knowing the correct part number? Is it interchangeable with any other VQ engine variants?
Obviously this is something that should be fixed immediately, I'm just worried about the intermittent stalling and having my big box stalling after taking off through a busy intersection or something!
Cheers
Glenn
I actually took my car to Nissan Hornsby to get the part and replaced it for me. You should only need to replace the faulty one.
Most Nissan dealers are reasonably helpful with sourcing solution. Just tell them it is an import and have your VIN handy.
I can certainly vouch for Nissan dealers at Brookvale & Hornsby being very helpful.
Cheers
Andy
Driver side CAM sensor - 23731-6J906
Passenger side CAM sensor - 23731-AL616
Crank sensor - 23731-AL606
I can't open my Parts Master at the moment, but I am pretty sure they are the same as what is used in the VQ35de engine.
DO NOT let the Nissan "expert" tell you they are the same as an Xtrail *f**king idiots*
The part numbers above are updated items as of 2004, but they may have updated since then (probably just to a "7" at the end in stead of a "6").
Also, I had the same 0345 error early this year. Replaced all three sensors which made no difference.
Turns out there was a bent connector for one of the CAM sensors (can't remember which bank) which was not allowing proper contact.
If you car has a silver circular sticker on the strut tower (or on/near the VIN plate) it means that your sensors were replaced as part of the factory recall in Japan. If this is the case, I'd be checking the connectors before handing it over to a Nissan "tech".
Oh, one last thing, make sure they let the starter motor cool for around 20-30seconds after each unsuccessful crank of the engine.
You don't want them to burn out your starter motor.
I replaced both of mine recently after the same issue........seems to be fine now.
Drivers side : 23731-6J906 is now 23731-6J90B and
Passenger side : 23731-AL616 is now 23731-AL61A
Nissan charged me $350
Where are you? I have some spares to try if you are in Melbourne.
I'm in Canberra :/
Wow thanks for the info guys! Man this forum is so helpful.
I'll have a look at the strut tower later today for that silver sticker, but I'm hoping it is just the sensors going bad.
I'll take the part numbers and VIN to the dealer, but I just remember last time I dealt with them they weren't particularly interested in dealing with imports.
Ouch for the $400 though! But what can you do....
Thanks again!
I'm in Canberra :/
Thanks again!
Try another dealer if you can? Might be a bit harder for you in Canberra I realise.
Some are really helpful, because they actually LIKE cars, and enjoy the challenge; like my local guy :thumbsup:,(he actually gets excited, because every time he looks for parts for me, he learns something new) others are just lazy, I think.
They can all access the parts listings, some just choose not to.
Hey Cam,
Is this what you're referring to? There are two little silver dots on the right hand side of the plate, smaller than a 5c coin. One of them is blank and the other has "R186" printed on it (sorry about the blurry phone photo).
Just to make sure I have it right, the 2 sensors are at the bumper side of the engine, and they're located just below the level of the plastic engine shroud, and mine are blue in color.
Where is the 3rd sensor?
If it's a case of a bent connector, is that pretty straight forward to see and fix yourself?
Thanks again
Glenn
Edited by GlennM35
And the crank angle sensor is underneath the engine, on the gearbox. It may just need a clean as it builds up with a lot of gunk.
Get underneath and remove it with a spanner, clean it and replace. See if the error goes away.
Hey Cam,
Thanks again
Glenn
Yep, R186 means that yours were replaced as part of the factory recall... so were mine.
The sensors are at the rear of the engine and have a green clip.
10mm socket is needed to remove the bolt that holds the sensor securely in the engine. Once this is removed, simply pull the sensor out, but try your best not to hit anything with it.
You will have to take the sensors out and have a good close look at both the sensor and the clip to see if it is a bent connector.
3rd sensor (crank angle sensor)? What he said^^ :)
Well I've worked out that 0345 is referring to the passenger side sensor (pretty confusing looking at G35 forums when they're left hand drive) and had a quick go at removing it... the instructions I found tell you how to take the connector clip off, but it's like it has been glued on! I'm pushing the little clip in while pulling the connector out but no go :/ Any tips?
Also went to Nissan in Phillip today, and the parts guy was actually quite helpful. We had a bit of a yarn about the M35s, he really likes them which I think helped!
Anyhow I got a quote for both sensors, the drivers side is ~140 and passenger side ~210 plus GST. Does that sound right? The drivers side is listed as "Sensor assy" and the passenger as "Sensor A-Crank", which might lead one to believe that it's the crank sensor, but the part number is right (23731-AL61A).
Mmm, they are the same sensor, just a different plug direction, so I dont understand why they are different prices. There are three sensors that could be the fault, like I said the crank sensor underneath may be dirty, have you tried cleaning it before blowing the cash? Are all the pins clean and straight? They have been replaced already remember.
The clip was a pain to remove as I remember put it came off eventually.(I may have used a screwdriver.)
You have taken the sensor out first? Silly question but it does help to have the sensor out of the engine before removing the clip.
You will need to push the end of the clip in first, then I think I squeezed the rear sides while pulling the connector out to remove it.
Definitely one of those items I was concerned about the possibility of breaking!
No not a silly question at all as I was trying to get it off while the sensor was still in there :whistling:
I'll have another crack on the weekend, properly this time!
  • 11 months later...
so it turns out all 3 sensors are available non gen, i had to replace the passengers cam sensor. it's in and working a gem, looked identical. that link on how to clear codes worked a treat, thanks for that!!
if anyone needs these sensors im happy to help, they are a lot cheaper!
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
