They said the data logged by the cars showed that none of these claimed events happened.
and fair enough. after all, their product was rubbished to a huge audience, for likely no reason besides the sake of entertainment.
i love top gear, but you gotta admit, they put shit on a lot of cars for no reason. sometimes they even praise a car, and then a few months later, they rubbish that same car.
jeremy changes his mind like a bitch on pms :)
i'm surprised they dont get sued more often.
Your not suppose to take what Mr Clarkson says seriously,
as Richard Hammond once said in one of the newer episodes:
Comparing a Beetle to a Porsche is like comparing an ape to a brain surgeon... or Jeremy to a brain surgeon
Edited by Mayuri Krab
I think most manfucturers take what top gear says like a grain of salt. The show is good, but it's purely a entertainment spectacle rather than a factual review. If you bought you car on the advice of Top Gear, I'd feel sorry for you.
That being said, I can understand an electric car company trying to get its foot in the market will take it more personally than BMW or Mercedes, whom have been building good cars and selling a lot for a long time.
yup,its just entertainment.season 1,episode 4,gtr is the car for the playstation generation is what clarkson said.who cares,he still likes em.even if he calls them datsuns.search u tube for him in the 1000hp r33.its yellow.
Hahaha.
"You put the balm on? Who told you to put the balm on? I didn't tell you to put the balm on. Why'd you put the balm on?"
Lol, Jackie Chiles had to be the best non-permanent character on that show.
Back on topic, does anyone know what 5th Gear said about the Tesla? They have better 'reviews' and I'd be interested to see how their experience differed from Top Gear's.
guys they are not suing them in the traditional sense. they are not asking for monetary compensation. if what they say is true then what they are asking for is more than reasonable.
"Tesla simply wants Top Gear to stop rebroadcasting the particular episode and to correct the record."
That seems fair to me given they claim to have the data logs as evidence.
+1
Big whoops, they're taking legal action to get their attentions after being ignored.
Good on them :)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
