  • Replies 482
Does anyone know where I can get my hands on a front bumper for a S1 and rough price as the fibreglass one on the Stag I recently got it stuffed and seems like cheaper to replace than repair? Prefer a Dayz one, but even a stock RS4 front would do.
Edited by Dingus
OK guys, 2nd last payment is pending and then I'm just waiting on gersfan.. if anyone knows him or how to get in contact with him please let me know or get him to contact me!
I shall allow him the weekend, if no response then I will place the order on Monday as we already have our minimum.
G`Day lads ,
just had the fun changing right hand front drive shaft,
not a bad job if the shaft stays as 1,
mine didn`t ,so had to find way to remove what was left in front diff,
after few rant`s i got it sorted,
you need to undo
sway bar,
bottom ball joint,
steering ball joint,
brake caliper & rotor,
i will add some more info soon,
i have old shaft so will look at costs of getting them serviced,
so if you need set we know costs,
cheer`s Chuckie.
i just sent it, sorry for the wait.. how do i find that ecu number?
should say it on the actual ecu
or get your vin fasted
ecu number..... i see you have a rs4s...
top off my head..
23710 0v800
or
23710 0v801
i have both of those
will let the 801 go if you need for 200, what i bought it for if you want to have a stock one just in case
Edited by Blizzerd
Ok all monies are in, I'm just trying to download Andreis' maps before I place the order but it's proving rather difficult :( He has an oddball ECU and they need a factory image for base programming.
I think my serial>USB converter is playing up and dropping the connection periodically :(
Does anyone have a proper USB consult cable that we could borrow? (i.e. doesn't need an adapter)
All sorted Jim and it wasn't as simple as the ECU number, I had to download the whole image from Andreis' ECU as it is an odd model and they haven't done one before.. It is a series 2 with a Neo engine but not the tiptronic auto, 25GT-X or something like that :blink: I sent the image to NIStune and just heard back that it's doable.
Oh and it was my serial>USB adapter that was playig up :( chuckies worked fine!
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
