  • Replies 482
seen a few white s1 and s2 stags over the last week.
1 was in the city on wellington street around 8pm or so
1 was coming off the graham farmer freeway on to grate eastern hwy at about 6 30 or so (S2stag)
and the last was just after the tunnel at the east parade exit at about 4 20 pm ( looked like a 260rs ) but was driving so not really see that well
Happy New year to all,
will have a Meet soon ,it will be heading south,
Big jim is sorting a run out,
The JDM run is coming up to so hope few can turnup,
Cheer`s Chuckie.
Ps Dash Mats ready in week or 2,so them wanting please PM.
got offered the opportunity to possibly be featured in hpi along with jash's rb315 stagea as jash is writing an article on how to build the "perfect" (eye of the beholder i think) stagea
Nice one for the the feature... also keen to get more info on Ash's stag after reading PI..
Also, any weekend with enough notice.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
