  • Replies 482
  • 1 month later...
Selling mine too..... http://www.skylinesaustralia.com/forums/topic/403770-bayside-blue-prime-edition-25t-rs4v-original-car-few-mods/
2000 S2 25T-RS4 V, Prime Edition with all the fruit.
Follow post to car sales advert with lots of pics.
$14,000 137,000 km
Edited by Appealing
Posting to say G'day, moved across from NSW recently with my silver M35.
Enjoying the process of trying to get the car inspected and license changed to WA while having a 9-5 job...
Got an inspection this coming saturday so fingers crossed its all good.
I get the impression there isn't a whole lot of M35's over here...
Cheers
Nick
Failed the inspection on window tint being too dark on the rear windows. One would think if it was able to be complianced and registered in nsw with window tint as is it wouldn't be an issue, obviously not.
Can anyone recommend a decent/cheap window tinter, or somewhere not as an*l.
Thrilled about throwing a hundred bucks away...
Mechanic said 20% on the rear windows. Both driver and passenger windows have already had tint removed which was all the was required for compliance.
Auto power joondalup. Only place I could find open on a Saturday.
Have a bookIng already with a place up in gin gin just in case this happened, but no point throwing another 60 bucks away. So I guess I get the tint removed...
Hey Nick,
If your stagea is anything like mine, the rear windows do not have tint film on them. It's tinted glass (privacy glass in nissans terms) and im pretty sure every m35 came stock with the same, so there isnt even an option to get less tinted glass.
Edited by Ross
look around the edge of the glass. if its tint film u will see that it dose not go all the way to the end of the glass ( crago windows ) if its the rear doors take the trim off and u will see the same at the bottom of the glass
other wise maby try nissan and give the vin number and see if thay can tell if it was form factory
Edited by whitenight27
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
