Just wondering what everyone's running on their boats.
When I had new KU31's put on (245/40/18) my steering went all heavy and crap at low speed. At first I thought the tyres must be underinflated...
Went to the servo, fronts were at 34 and rears at 36. Pumped all 4 to 39(!) Is this too high?
Now I realise the increased tyre width probably has more to do with it....right?
https://www.sau.com.au/forums/topic/360097-tyre-pressure/
  • Replies 44
read the pressure rating of the tyre. it will have a maximum. but too high will cause excess wear in the centre, an underinflated tyre will wear onthe outside.
a too firm tyre will be bumpy, especially with aftermarket suspension. i think i run mine at 38 front and 36 rear. but this is when cold. always check when cold
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5749475
I was runing 34psi but after a run down Putty road on the weekend it was too rough with the coil overs. So on the return trip, i lowered em to 28psi. Car was much better to drive and not quiet as rough. Still handled the corners beautifully!!
I run these tyres: http://www.falkentire.com/Tires/Passenger-Car/Azenis-RT-615K-14
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5749569
i like that test.
but yep, i run 38 front and rear - tested when cold.
good investment is a digital pressure gauge. dont trust the ones at the servos. i check pressures weekly. car feels nicer and less jittery over low speed bumps when the pressure is down around 36 (which is what most tyre places will reccommend) but i reun a slightly higher pressure to protect the wheels, and to counter some of the camber wear by rounding the center of the contact patch.
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5749929
I run 38 - 40psi but I believe your heavy steering is caused by the wider rims/tyres and different offset. It gets worse the wider you go.
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5749977
That's all horribly low for low profile 18's...
I run my 235/40/18's at 45psi cold, even 42psi doesn't feel right and anything under 40psi feels terrible.
You must have good suspension to compensate your tyres which are as hard as concrete!!
Must be bloody slippery in the wet/rain with those pressures.
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5750078
50psi!? that is ridiculous. and why would you run it higher if you're lashing it? should be running it lower if anything. otherwise it just turns into a roller skate - you will get better grip with lower pressure, plus it will allow for expansion of the air as the increased heat levels build.
only people i know who run those pressures are the VIP guys who run super stretched tyres and huge camber - helps prolong tyre life and keeps the tyre seated on the bead.
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5750128
no
Should mention, I don't have a stagea and just realised this is the stagea section..
Edited by Ten Four
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5750145
on drift days you run a higher pressure in the rear. also some tyres are rated to 50psi. i remember a set i had on my S13, 52psi was the maximum. i ran them at 44psi.
if 50psi is over the maximum rating, youre taking a risk IMO
https://www.sau.com.au/forums/topic/360097-tyre-pressure/#findComment-5750151
