Mark saw your at today at MM and all I can say is fkn amazing, took my r35 to get it a RWC (moved to qld) and Trent showed me around the place. I'm gonna start looking into getting a set of track wheels and I'm thinking about the ones you have.
Gratz on the car, great work and a great team down at MM, I take my hat off to the lot of you :)
Will definitely try to get to a few events and make my way to WTAC in Syd
Edited by I8AV8
  • Replies 743
thanks! would be great to catch up at the track.:thumbsup:
Not yet.
Hehehe. Everyone's sweating on the freakin' carbon turning up.
Drew's is alive now and sounds grumpy. If all going well (when the carbon turns up) we will see you out at QR next week.
It's getting exciting isn't it.
Cheers
Marty
The hassle with the availability of the carbon parts is beyond a joke and we are far from impressed. Not only has it delayed test days in the past but also means that people involved now will have to work ALL weekend to even get the car to the track for monday testing. Not to mention the additional cost in freight/overtime etc. Not happy Jan!
Edited by MercuryMotorsport
At least you guys have a plan B for parts and can drive it. Drew has no front end at all and it's even due before your parts. Hope he pulls his finger out and finishes the carbon asap. We are starting to get a little nervous!
Cheers
Marty
Unfortunately it always seems to be outside contractors and suppliers who are the hold up whenever the pressure is on.
I hope you guys get it sorted, I'm super keen to see how it performs!
+1
When I worked as a small business manager I was project manager for many jobs, some going into the millions of dollars in costs.
Here in Adelaide we found the eastern seaboard states were never on the same 'level' with us timeframe-wise. If the interstate supplier had quoted 8 weeks for manufacture (add in 1 week for delivery, which I always arranged same time order was placed for product) we sort of had to allow say 10 weeks for manufacture, sometimes 12 (50% longer than quoted), simply because the late supply happened ALL the time. It was a guarantee that somewhere along the supply chain in NSW or Victoria a company would end up holding up our project. Main customer was the SA Govt. so it became nothing short of embarrassing. Didnt matter if I was in contact weekly to be updated on delivery timeframe, guaranteed the last week we'd get the 'sorry' speach......
Experienced this over 12 years in my job, it's the one part of the job I dont miss (got sacked once my kneecaps were surgically removed).
I hope you can work it out in good time.
