Yeppers, some oem pumps are well capable of doing the job. Many z32's making 500+hp on stock pumps, however they are getting old, so a new OEM pump is always recommended :)
That's pretty impressive Dean. Are u running a relay on the factory wiring?
Have u tested the pump to see how much more it has got and what it could potentially support in terms of kw?
It was a full factory setup, factory wiring, like it had never been opened.
I've got twin nismos now so I can't compare....
Why did u upgrade your pump? Making more power or for safety factor?
I think I've hit a wall as I cannot source submersible fuel hose with an ID to accommodate the fuel pump inlet which is 15mm. I tried pirtek, gates, speed flow, earls and purple pig.
Gates stock submersible hose in 2 sizes and these only run up to 9.5mm.
Does anyone have any ideas on the best way to mate my fuel sock to the fuel pump? Fuel pump is a push hose fitting and the fuel sock has a female push fitting with an ID of 24mm. The generic fuel hose does infact work in terms of size for ID and OD, however, the outer skin will disintegrate as it sits in the fuel tank.
If I have no other option, I may run speedflow -10 push hose as EFI Performance suggested this and apparently does not break down in fuel (even though speedflow stated to me that it is not rated for fuel submersion.
When I bought my car the previous owner said it had a bosch 044
Had it tuned running 340rwkw no fuel supple issues what so-ever, even went drags 3 times etc
Upgraded last month to a walbro e85 pump only to find it had a stock pump in the tank lol
Its amazing what flow these OEM pumps can support. I might test mine in a bucket and see how many litres it flows over 1 minute...what is the best way to test this though, direct to the battery?
Marko, just cut off some hose off a fire truck. She'll be right mate ;)
how about some seasoned bong hose? Loool
I want to do back2back flow testing with the OEM pump and pierburg. I reconnected the OEM pump but the trigger switches it off after 5 sec.. can I connect the pump to the battery direct as I want to measure flow into a bucket over a period of 1 minute so that I can calculate LPH.
Update time.
I decided to flow test my OEM pump direct from the battery and was very surprised by the results.
Over a period of 30seconds, it flowed 2.7ltrs which equates to 324LPH.
The pump even ran low and started blowing bubbles as I couldn't fill up the 2 ltr bottle it was sitting in quick enough.
Am I getting a higher voltage / power supply from the battery, rather than the fuel pump harness located in the boot? How can the pump flow at such a rate?
Off the return, that way the fpr will hold it at the correct pressure/restriction. It should be a reasonable indication of the flow as long as there are no other restrictions. Eg. Blocked fuel filter crimped line ect.
just wondering
are stock 34GTT pumps enough to use as lift pumps for a surge tanks with two 044s. This is for 350kw+ on e85
or would using the Deatschwerks 300lph as a lift and two 044s be overkill/enough?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
