  • Replies 62
Can it work or will it be a better idea to run it off used cooking oil like some people do and apparently it's very cost effective?
OMG you were serious... umm google the differences between petrol engines and diesel, or better yet put some diesel in your skyline and report back....
Don't listen to half these idiots, they have no idea about the benefits of diesel and cooking oil.
Just test it out on one of your parents cars. Put a mixture of cooking oil (I like the Coles brand, I find it gives better torque than the bigger name brands) and diesel in at the servo. You will want to get the car up to around 5000RPM and hold it there as soon as you leave the servo so the ECU can learn the new mixtures and recalibrate.
The vehicle may jerk around a bit and make some funny noises but this is just the spark plugs readjusting for the new temperature of the diesel. If the jerking gets to rough you will have to give it more RPM, closer to 6000rpm.
Why do you think V8 Supercars are so fast as they are, they know the secrets ;)
Ive tried this, its proven 100%, i tried Extra Virgin olive oil first and it ran abit rich. So tried coles brand canola and it run like a beauty.
this was tested on a 32 gtr btw.
Cmon guys, it's not really fair if you only give a guy half the information he needs. You have to perform a cylinder head port to cope with the extra compression ratio and flow the engine will now need. The Honda Sandbag method works best
Instructions here:
http://www.audiforums.com/forum/showthread.php?t=80267
BTW, the idiot in that instruction thread went wrong because it doesn't work on German cars, only Japanese so with a Skyline you'll be sweet
haha that's awesome the rougher it get the high it has to rev
Instructions here:
Farken LOL!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
