when I went to pull my turbos off the first time, they were seized as buggery. Was really hard to crack them off.
I ran a tap over the threads and then put a dab of graphite-impregnated anti-seize on them. Then tightened them up the best I could.
5,000 k's later I had to pull them off to do my rb30 conversion. They still were clamped on nicely, but way easier to crack and wind off.
Where does everyone get the stainless studs from?
I get mine here, not sure what the thread pitch is on the RB's though, is it 1.5mm or 1.25?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=200356383346&ssPageName=STRK:MEWAX:IT#ht_830wt_1139
After mine were a bitch to get off the 1st time I have the whole shebang a coat of WD40. (yes it burns off after 10mins). It's been off a few times and swapped turbo since and no problems - also no nuts coming loose either and they aren't stupidly tight either.
i have had problems a couple of time with stainless steel binding. its a f**ker when it does.
i dont bother using SS these days. i find high tensile bolt/stud in right size for what im doing and coat it with Caterpillar antiseize paste which is basically a copper paste. its not cheap buts its free for me and and amazing product.
deals with high temperatures extreamly well.
anything from caterpillar usually is great gear. on a side note, i use caterpillar gear oils in my box and diff in my track car.
Are you changing the turbo studs too? The 4 which hold the turbo on? If so what length and pitch are the standard ones? I need 4 new ones. My old manifold bolts looked like steel stud copper nut. Piece of piss to take both out after 30thou driving. New car has stock shit so I don't plan to ever take the manifold off lol. Need to replace the turbo ones as new turbo is going on. I've got some studs suitable but far too long and I really don't want to be here cutting away...
Lol actually I dont work for caterpillar lol. I work for a company called consolidated facilitations. Im an electrician by trade. My old man is a deisel fitter by trade and territory manager for caterpillar. Got a few mates who work in service for cat or in the mines doing break down work on cat gear so getting their products is not a hassel lets just say lol.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
